[APP][Pro] Eufy Clean
@Jomi thats how it works right now. But the mop cleaning is seen as cleaning can’t change that
Martijn, I was looking into other app on Github, but your app is supreme. Well done
@martijnpoppen I found this integration for a Roomba, maybe this could help you to get all kind of commands of the Eufy to? Integrating Roomba with Home Assistant
@Brian_Monninkhof I don’t see how that’s related to this project? Eufy uses Tuya and MQTT while Roombase use local P2P
It’s not that I can’t find the commands. It’s just i need something like spending a week on it to make it work, which is currently something i’m not planning to do.
So when I feel like it and have time for it i’ll probably dive into it. But with the Eufy Mega project coming up this is not the highest prio
Martijn, you are doing a great job! Just thought this could help.
@martijnpoppen
Nice App, works well. However i don’t know if it’s the iOS app that’s not updating properly or something changed With S1 pro. But i tested changing to different modes with flows, but they don’t seem to change properly in the app (and i’m assuming also the RoboVac)
So changing modes between mopping and sweeping through flows works: the change is also visible in the iOS app.
Changing “intensity” doesn’t seem to change anything, i doesn’t seem to be a mode on the S1 Pro anymore.
Changing “water level” to medium changes it to “low”. Levels: High and Low work
Changing “Clean Speed” to any value, changes it “silent”.
This is with a S1 Pro, firmware 7.0.126.
Eufy Clean iOS 3.4.13
If you could look into this that would be great. Thanks.
@Stephan_Widjaja will check
Maybe I need access to a S1 :wink:
Sinterklaas kapoentje, gooi wat in Martijn’s schoentje, gooi wat in zijn laarsje, dank u sinterklaasje!!
Hey,
I am pretty new to Homey Pro and I am trying to add the Eufy L60 via the app. But it is stuck in “Searching for Devices” for at least 20+ minutes before I give up. Is that device not supported?
Thanks!
Stefan
EDIT: I decided to Ctrl + F this topic and I see its indeed not supported. :upside_down_face:
Hi @Stefan_Weijers
The L60 is supported [APP][Pro] Eufy Clean - #3 by martijnpoppen
Can you send a diagnostic report?
Hi, the connection between our G30 was gone, tried to reconnect but some how I can not connect it anymore.
In the official Eufy app, the G30 is present and works perfect.
I completley removed the app from Homey and tried to the RoboVac, but keep getting the ‘no new devices’ error. I double checked my username and password.
Maybe someone knows what I’m doing wrong?
@martijnpoppen: I’ll sent you the diagnostigs report :wink:
2d3ad1ac-7fff-4020-916f-125bd8fcd5ef
e
@Hermann_Stengel please send a diagnostic report
@Hermann_Stengel I think the report was from you right? (i can’t see the sender…)
But if it was yours:
Incorrect account ID or password
Hi @martijnpoppen
I’m not sure the report was mine, however I reset my password several times and used diferent mail adresses and removed and after restart, installed the app on Homey again, but still get the no new devices error.
I’ll send the report again, maybe you can have a look in it when you have time. But please, don’t hurry no rush at all! :slight_smile:
@Hermann_Stengel
I still see Incorrect account ID or password
Sometimes it helps to create a extra eufy account and share your robovacs with that account
Is that something you could try?
Hi @martijnpoppen , I am new to this forum. But I encounter the same problems as @Hermann_Stengel. I can no longer connect my Omni X10 via the Homey Pro. I could use it for a while, but once the internet went down, it became unavailable. I managed to set it up again a second time. However, same thing happened with the internet. Now when I log in with the Eufy Clean app, it no longer appears as a new device to add. Do you have any idea what could be causing this?
Hi @PhilipvdK
This is a English topic please translate your post
Please send a diagnostic report
Hi @martijnpoppen , Apologies, I changed it now! I created the diagnostic report and got the code, the code is: 17f5a2ee-242a-4760-baa4-1f96584ecdd6
@PhilipvdK as far as I see you used a incorrect email and password combination
Hi @martijnpoppen this was not the case, later I did enter the correct login. I fixed it now btw, if you reset the wifi on the Omni X10 with the left and most right button. and redownload the app for homey, it seems to find it again. I did stay on the 2.4 GHz network the whole time so this might also helped. but I can use my flows again so I am very glad with this!
