[APP][Pro] Eufy Clean
e648dcdb-ca6a-4ce4-ae89-6a806072c011
Hopefully it works now🙏🏻
@Danny_Bakker report is again empty. There’s no activity. Did you restart the app??
Not yet
@Danny_Bakker its really strange I would expect some logs but it looks like it still the same as yesterday
Can you maybe restart homey as well? Might be that the logs are frozen
Edit: i experience the same with a different app this morning, a Homey restart fixed it
Hopefully the above issue is resolved.
I have two questions:
There are many posts for Eufy clean, is there a way to cluster them in e.g. sub-topics or use tags? Then you don’t have to ready everything :grinning:.
Eufy clean works great, except that my Omni X10 is not responding to ‘when status changed to stopped’, do ….
Does this work for others?
@Jomi which issue are you referring to?
And who’s is in charge of making sure those topics gets clustered properly and maintain that and make sure that everybody asks his question in the right topic? :face_with_peeking_eye:
Can you share the flow? This is kind generic
@Jomi please send a report next time it doesn’t work → How To
@martijnpoppen Is it possible to trigger the emptying of the dust-bin only via a flowcard? I have a X10 and I want to control when it empties the dust-bin (but not clean the mops). Is that possible?
@Wouterr Unfortunately not. Maybe in the future but currently not possible
Tx, error report 33571d82-65cb-4aaf-bb72-4402090ff74f
@Jomi looks like the connection disappears a lot of times. So it is not connected all the time to homey.
Can you verify your Wi-Fi connection to the eufy robovac
Hi @martijnpoppen, unfortunately it does not work. I never received a confirmation in Homey that the Eufy cleaner stopt cleaning. I do get it from the Eufy app, but I can not make a flow with the app. Thanks for investigating.
@Jomi I already investigated and send you a message about that :sweat_smile: [APP][Pro] Eufy Clean - #690 by martijnpoppen
@martijnpoppen compliments to you for building the app. I just bought a Eufy S1 pro, and it works like a charm.
My first flow for the Eufy S1 Pro.
As soon as rooms are available there will be a lot of flows possible.
My wish list:
  • Cleaning attempts 1x and 2x
  • change floor plan
  • notification finishing mop cleaning
  • switch between vacuum cleaning and mopping
  • clean a specific room
@Brian_Monninkhof thanks!
  • This is not possible
  • change floor plan
  • You can do that yourself with a flow
  • Already possible in flows
  • Not possible (how to select the room?)
Thx for the response!
I mean with mop cleaning, the status of cleaning the mop not mopping the floor :wink:
@Brian_Monninkhof currently not possible to get values from the base station
@Jomi instead of using stopped can you try charging?
Stopped is when it’s in the middle of the room and you paused/stopped it.
Docked is when it does nothing in the dock
Charging is when it’s done sweeping/mopping and is back in the dock (so when it’s just finished)
Hi Martijn
Started is working, charging is working but not a signal when the cleaning is over.
This means in my case that the cleaner is drying it’s pads but without the end signal, the door of the small room the cleaner is in is not closing.
I do see a message sent by the Eufy app, that cleaning has ended. If that signal could be picked up, that would be great :pray:
