Thanks, i wil do it this weekend!
I have made a diagnostic report.
Now it doesnt stay loading, but it says no devices found. But i have the Eufy L60 SES that stands on the list of working with the homey app.
This is de diagnostic code:
082fcd7c-7a9f-4c3e-a8f1-1164b7a73a08
Hope you can help.
@Rembo038 from what i can see in the logs is that you’re using a wrong email and password combo. So please check if those are correct
To be sure i changed the password, but still getting the same problem. In the Eufy clean app on my android phone has no problem with the login credentials.
New diagnostic report after changing the password and try again to add the euft vaccum:
af1caff0-1b4d-488e-b295-c753b94a100d
@Rembo038 strange it really can’t find a device but I don’t see any errors
Can you try a restart of the app as well?
@Rembo038 nice that it works
That won’t be possible yet. i have to investigate if that will be possible at all
Okay, hope you can figure it out.
I have a question. If I set up a flow to clean with the robot, what command is actually being executed? Is it like simply pressing the clean button in the app? So, what is the equivalent of the clean command in Homey? I hope this is understandable ![]()
Hey @Laszlo_Cseh
Yes the same if you click start cleaning in the app
Of course you can change the specific clean modes via the other flow cards
@Robin_van_Kekem Please elaborate
There are new capabilities for Homey in firmware 12.2.0
@Robin_van_Kekem Yes I’m aware, but still not sure why you’re sending that in this topic?
There is a new enum for vacuum cleaner job mode
@Robin_van_Kekem as I mentioned earlier, I’m already aware of the new capabilities. However, your message doesn’t address my original question. Can you clarify the purpose of your comment?
Do you want me to integrate this or is it just for reference?
Maybe you could use in the app
@Robin_van_Kekem This capability won’t add much value to the current state of the app. Therefore I chose not to implement it.
Anyone else having trouble using the “docked”-condition (“and”-card) in a flow? In my case it seems stuck in a false-condition although the trigger and device status page do report the correct values.
@KevlarD please send a diagnostic report after triggering your flow
