How to update to this versjon (1.17)? Mine is 10.0.10, auto update enabled. (And I’m very thankfull for the app, just missing correct energy calculation from Super TR in regulator mode).
Seems like thermostats kWh reading is still wrong. It is not going bananas as before, but is showing too small consumption to actual. After 2 days consumption my living room termostat claims total meter consumption of 2.2 kWh, while my calculation in advance flow for daily consumption so far is 13 kWh. The effect of heating is 2200 W.
I experience an issue with energy consumption reading with all my Elko Thermostats. No energy consumption has been recorded and power is 0 even though the heating cables are on. Anyone knows a solution for this?
This applies for all my Elko thermostats and has been this way since I first added them to Homey. Tried both of the last two versions of the Elko app.
On my installed Thermostat devices I experience that it is not possible to change between Regulator and Thermostat mode with the latest version. I can no longer change the regulator%. I’m using them as a regulator to regulate a heat cable on a pipeline. What can I do to fix the problem?
So I need to reconnect/ reinstall the termostats, and make change on all my flows? (Hours of work)
The thermostats is not onsite (in my cabin). Is there any other way to do this?
I will see if I can include a legacy driver in the stable release. But the code is much unstable when both capabilities is included, resulting in loads of errors in Homey core.
OK, but there are fixes that worked fine in the latest version. The no test version has several bugs.
I can’t understand why you made the choose to make this change. It is one device and it’s functionality is that it can be used/ change between Regulator and Thermo mode.
Ok, I will go back to original code in next update. See if there is more do be done to make it more stable. I must rebuild the whole settings part that will result in some major changed and there might be possible that it needs rejoining anyway. I will ser what I can do
New update on ELKO SMART app in test now. @Mareno - This is for you
v. 1.1.10:
Updated settings handling on all devices. Rebuilt settings on Thermostat. Better handling on Thermostat <-> Regulator change. Introduced new ELKO Smart devices. Multiwire turn dimmer added as own device to add settings. Please reconfigure settings after update since this can be out of sync after this update.
