[APP][Pro] ELKO Smart (deprecated)
Hi @Tobster Have you tried to disconnect one of the old dimmers totally from Homey and paired it again? Mine old worked just fine until I disconnected them. I thought it was a good idea to start from scratch with all the new software. I get the “someting went wrong” message.
Geir
Hmmm…no, I haven’t tried that while I am on 5.0. And based on your experience I do not think I will try that either :stuck_out_tongue_closed_eyes:
Thought so. I do understand why you don’t want to try :slight_smile:
man. 15. feb. 2021 kl. 21:22 skrev TB via Homey Community Forum <athom@discoursemail.com>:
There is no way to turn of the thermostat with a zigbee command I’m afraid :-/
@prj_84 Is there anything I can do to help you debug? Please let me know.
I have the ESH Super TR RF PH - Thermostat, operated in regulator mode. I can set the regulator % in Homey, but I can not do this in a flow. Is there something I am missing, or is the functionality not implemented?
What is new in the latest versions, 1.0.3 and 1.0.4?
I did not mean to turn if completely off, but is it possible to turn off the heating? Or alternatively allow to set the temperature lower than 5 degrees (will give the same result) which is the lowest I can set the temperature now.
ELKO Super TR RF has the option for night mode, but when I use a flow for lowering the night temperature, it just lowers the temperature, rather than setting the “lowered mode”. According to the instructions manual the display should display the temperature in green when it is in a lowerd setting.
If you want help developing this feature (and the app), please open your Github-repo, and I will be able to make a pull-request :slight_smile:
Hi! I have this on the drawingboard, but some other projects ahead i que! Thanks for feedback
Hi! I checked the documentation and 5 deg. is lowest possible temperature. But if you set the thermostat to regulator mode it is possible to set 0%. Can that help you? It is not possible to turn of heating. The attribute is read only
Hi! Yes it does. I had this implemented in the code, but an error in the new zigbee core made it impossible to activate both Nightmode, frostguard and toggle childlock on/off. I then later removed the code during code cleanup before the test release i august/september. I will be more than happy to share the Github-repo with you all. There is just to much on my plate at the moment, so I do not have all the time I need to maintain and develop in the speed I want. INFO: There is just a Master branch with the beta app and some devices that do not work for now since there is missing IASZONE enrollment in the new Zigbee core, and some missing cluster info that I need from ELKO. I just clean them out locally before I publish new versions :slight_smile: I have made the repo public.
Good idea. That can absolutely solve the problem - I will try that. Thank you!
I have homey version 5.0.0
I try to connect to Elko smartdim vri uni. I follow the instructions but homey cant find any dim.
I connected esh plus super tr rf, and it worked Fantastic.
Anyone that has a clue to fix this
Try to factory reset dimmer. Total of 4 clicks, but on 4th time hold for 10 sec. After this try to add again.
Thank you
That worked😊
@Oldman Did you solve this? I reset the Zigbee network since I had constant problems with devices leaving, and now pre-2019 316GLED and Thermostat won’t connect.
Edit: I do see that Homey has now changed to channel 21, which is probably good. But can the Elko components have issues with this? Do they need a harder reset than just the pairing command?
Edit 2: Yes, changing to channel 11 made them connect instantly
Edit 3: It worked fine to switch to 11, add the devices, and then switch back to 21. I don’t know if that causes trouble for any devices who don’t support channel switching that well or not (ref. the warning given by Homey).
Hello! I am totally new to Homey, but I really like the way this app integrates my switches and dimmers. But I am wondering if you plan to add support for the 4-button switch ( https://proff.elko.no/smartbryter-tradlos/smartbryter-tradlos-plus-so-article3217-3016.html)?
Thank you for making this app! :smiley:
Yes! allready have the unit, but not so much spare time to develop atm. But it is in the pipline :slight_smile:
Perfect! Once again thank you for developing the app! :slight_smile:
I have trouble getting the Elko 316gled rf to connect with homey. Message: something went wrong, try again later.
I used it before with Elko app and it worked flawless.
Do anyone know how to connect it to homey?
