Thanks for explaining the issue for me - I’ve found a bug and pushed v1.6.5 which should fix this
Hey Tim, I’m contemplating a complete re-write of the app to migrate to better integration, better authentication and something that will auto-integrate the capabilities of the appliances to allow for improve existing support, but also future support of appliances that have not yet been seen/discovered. I’ll update this forum if that direction comes to life.
Hi, my Electrolux dishwasher status in Homey stops updating automatically.
The Electrolux app shows the current state correctly, but Homey keeps an old state.
Restarting the Electrolux AEG Homey app immediately refreshes the dishwasher to the correct state, but later it becomes stale again.
Diagnostic report ID: a3b98ee8-c46d-4092-a5d0-13a65f940f33
All - a test version 2.0 of the next App has been posted to Electrolux AEG | Homey
Switched to the official Electrolux Group Developer API. Email/password login is no longer supported - open the app settings and enter an API key, access token and refresh token from developer.electrolux.one.
You should re-read the ReadMe page and ensure you’ve understood what is now required for this new version of the app
Good morning all.
I have an issue with my AEG at this moment.
I’ve done the APi setup and device is connected to Homey . But I can’t turn it on or off or make any changes? Any suggestions
Kind regards
Pascal
Looks like the API has changed more than I realised - I’m looking into this and will have an update shortly.
@gslender In good news the API changes have fixed several issues. Including dishwashers being able to correctly grab the correct appliance state. Don’t you dare change that too much
Thank you for all your efforts, it is really appreciated!
v2.0.2 was just pushed out that fixes command problems that for most, should have no noticeable impact - other DAM appliances will now work (hopefully) but I’m unable to test these… so unsure. I’ve also added some error messages and better logging. So fingers crossed this works.
Good morning
Thanks in advance i hope the update fixes it
And thanks for the time and effort I’ll post the results if my pro gets the update and keep you posted
Kind regards
Pascal
Hi all,
I have the AEG TB8SB73ZAB SteamPro. But unfortunately I only can see if the oven is on or off. No signs of the current temperature or the target temperature for example. Another thing when I try to put on the light an error shows: command validation failed. Capability not found. Has anyone solutions for these problems?
