Hello again.
Wanted to install your app again because the other app has problems again, but I get the following message:
Also the test version gets the same message.
I have the Homey Pro Early 2019 version.
I suspect that’s because it needs v12 of Homey
You were right. Working now.
I am one of the people that doesn’t want to auto-update, I was still on v11.0.0, you can see the result here.
Thanks.
I sended (PM) you the 2 jsons, the second json only has the {}
Test v1.3.4 is in the store. That should be fixed for PURE devices.
This morning I received a notification that the washing machine was done, even though we weren’t running a load. I created a trigger for when the time to end is 0, and apparently, it was triggered by the app update this morning. Could that be possible?
For testing, I made some extra flows to log the status in order to see what’s happening. You can see these events at 09:37.
This has been resolved and will be in a future update.
I’ll also look at how to ensure the startup values are at zero where possible. Note that an app update will reset values and storing them in flash may not be ideal as it would wear out the SSD. Hopefully just making them zero will be valid during app restart/updates
Since the update a few hours ago, my AirPurifier gives this:
Even after a restart and filling in the password again (to be sure), still the same result.
Edit: I see on Github more people have the same trouble/problem, I will be patient for the fix.
Fixed it latest release v1.4.14
Thanks, fixed.
Hi - some random user has submitted a diagnostic report without leaving a method for me to contact them via this forum or via Github. If you wish to reply here or via Github Issue I can discuss the issue you are having.
Hi @gslender,
I’m trying to get a notification out when our washer (AEG pnc # 914550478) is finished. I use the following flow:
But the device status “END OF CYCLE” doesn’t seem to work even if the device info says it has thtat status.
Any idea what this can be?
Not really. You will need to troubleshoot this further and perhaps add some events and notifications capturing the status and output of things at various stages to help me.
As you can probably imagine, I don’t have all the AEG or Electrolux appliances to test all of this - so I need to rely on good feedback and logs from the community. If you can’t do that, then I don’t think there is much else I can do.
This isn’t what I require - I need the app logs as per my PM reply.
Hi!
I am unable to disable OTP in my Electrolux app, and therefore, I cannot use this integration either.
Any ideas?
Regards, Primoz.
As per the instructions, you must logout of the mobile app and re-login using username/password and bypass the OTP option
Have you been able to resolve this issue with @gslender ? I have the same type of issues with my dishwasher. It looks like the status returned is End Of Cycle in stead of END OF CYCLE.
Nope, had to work around it in an advanced flow. Working fine though.
