Thanks for reporting. I’ll look into possible reasons for that.
I think you should be able to fix it for now by restarting the App. Please let me know if that resolves it? I’ll see if I can prevent it from happening altogether.
Restarting the app didn’t solve it.
Ok, then at least removing and re-adding the device should work if you want to go through that trouble. I’ll look into it soon, hopefully this weekend.
After using my Dyson for some weeks now, unfortunately today I lost my internet connection. After rebooting my modem everything seems fine although the Dyson wasn’t connected anymore. Ive tried everything, even deleting te app, reinstall and search for the fan again, but nothing seems working, the device simply can’t be found anymore.
Any tips?
Yes, if you read up a bit, you see that you have to unplug the fans from power, and then plug it back in. That will solve it.
I experienced that as well and Mark who developed this amazing app said he will try to see if he can make it more reliable in a future update:
If you never switch off the fan and leave it on automatic, you might experience the same issue after maybe a week or two. Unplugging your fan from power and re-plugging it again should fix it for now.
Thanks for answering,
Unfortunately it doesn’t, i’ve tested this multiple times, it still can’t be found anymore. Regarding the official app for Dyson, this app didn’t find the device not once. So the Dyson Fans app is still the most trustworthy.
To narrow down the issue most likely caused by mDNS being blocked on your network, I would confirm it with the tool above.
Great, thanks for testing it. At least we know your Dyson fan does it’s job to advertise itelf on this particular network.
Did you run this tool from the exact same network your Homey is connected to? If your Homey is connected using the LAN, test should be completed on PC / MAC connected to the same LAN as well.
Just to be sure, you are still able to control your fan using the official Dyson App directly on your Mobile Phone (not Homey related)?
How is your network looks like?
Hi Didier,
It’s becoming more interesting everyday. Thank you for your support so far.
This is what I can tell you regarding your questions:
So far…
Hi Niels,
Sorry to hear it’s still not working for you. I’m going to ask you some things you probably already tried and answered, but I need a picture as complete as possible to help you, so please bare with me :).
Indeed I did all those things already,
I have published a new test version of the App here:
I do not expect this will solve your issue immediately, but I’ve added some additional logging that might just help us figure out what’s going wrong.
Could you please install this test version and try to add your device. At the point where it fails, please send in a diagnostics report. Hopefully I’ll be able to determine what goes wrong for you with that information.
@Niels_van_der_Voort I forgot to mention: please make sure you uninstall the currently installed version first, such that we can test this from as clean a situation as possible.
I’ve uninstalled the software, went to the homey test version en installed this new 1.01 version.
Indeed it didn’t solve the problem, the device is still not there.
Niels
Hi Niels,
Did you send a diagnostics report for the App? I did not receive one… Hopefully that will tell us more about why things are not working on your end.
It is necessary for the diagnostics report to be sent right after installing a clean install (uninstall again first if any version is already installed), logging in with Dyson and searching / selecting devices. Otherwise it will probably not contain the required discovery information.
I’ll look at it asap after I receive it.
Cheers, Mark
I’ve just repeated the procedure after enabling the diagnostic report switch.
Thanks
Awesome app finally have heating control for my dyson heat and cool link, only issue is the power control doesn’t work and gets an error every time “missing capability listener: on/off”
the offical dyson app still works so i will use that for power for now.
@1400 compared to “official” app, yours works - awesome. But it only finds one of my two TP07 dysons unfortunatelly ![]()
