And: “A specific device is paused” - check whether a device currently has an active pause.
Then:
“Pause device until date” - device picker + a native date picker.
“Pause device until date (variable)” - same thing, but the date is a text field so you can drop in a token or a Homey Logic variable instead of a fixed date, for a computed/dynamic pause date.
“Resume device” - clears an active pause early, so it’s monitored again right away instead of waiting for the date.
Am on 1.9.0.
Yes some devices do not provide battery information. Am having issues with some Aqara devices but here we are talking about devolo heater devices that do have battery information like:
Found it - real bug on my end. Turns out the battery type is reliably populated in energyObj.batteries, not energy.batteries (which I was reading) - checked against real devices, and energy.batteries was empty for the large majority even when energyObj.batteries had the correct value. Fixed in 1.9.3.
Also added a manual override for cases where Homey genuinely has nothing (sounds like your Aqara devices might be in that camp) - under a device’s “Details”, there’s now a free-text “Battery type (manual)” field. Whatever you type there shows up instead of the auto-detected value, both in the widget and the details view. Leave it empty and it keeps using auto-detection.
New: three “any device” condition cards — Any device is unavailable / is not reporting / has low battery — no device picker needed, handy for flows hung off the summary triggers where you don’t know in advance which device tripped it.
As always, happy to hear what’s working and what isn’t
Was looking at my zwave sirene. Homey app had a popup. Something like: haven‘t seen the device a long time. Couldn‘t then open the device. Tried a „test“ with device watchdog. As the device is under: not watched no indication wether the test worked or not. Looks like it did. Only I get only an okay when the device is on the watched list. Is it possible to get an okay on test when device is on the not watched list?
Thx for the input. Just shipped v1.9.6 with a small addition: the Test button now shows a clear “✓ Reachable” (or the error) directly on the button itself for a couple of seconds after every test — regardless of whether the device is on the monitored list or not. Should give you the confirmation you were missing on that sirene.
You are correct, they are under not monitored. I asumed when having selected all devices the search does include the not monitored ones too. Presently I have to remember to search 2 places. A bit confusing, or?
That message now only appears when a search truly has zero results anywhere.
While I was in there, I also made search results easier to actually see: any zone group containing a match now auto-expands as you type, instead of leaving you to click open a collapsed zone to find what you just searched for.
Just had to restart my homey and watchdog tells me thirty something devices are not reporting. Now down to 9 devices. Any idea. Maybe wait a while after a restart bevor a scan starts?
Had a look at the last seen time stamp. After 18 min all have one. Started several scans via widget still some are not talking?
Thanks for the detailed report, that’s really useful. Two separate things going on there:
The initial burst (30+ → 9): Right after a Homey restart, the app’s own device cache isn’t fully settled yet when the first scan runs - that’s very likely what caused the temporary spike, exactly your own suspicion. Just shipped v1.9.8 with a new setting: “Wait after app start (minutes)” (default 2 min) - delays only that very first automatic scan after a restart, giving things time to settle first. Manual scans and every later scan are unaffected.
The remaining 9: Looking at your screenshot, most of those (window/door sensors, the flood sensor, rain sensor) show “last update” from days or even months ago (e.g. 23.3. for the flood sensor) - that’s unrelated to the restart, they’re just event-driven sensors that haven’t had a reason to send a new value in a while. Not a bug, just how event-driven devices work - see the FAQ entry on “not reporting” for more on that.
