I want a light device with 4 buttons. 1 to control all 3 lights, the other 3 to control the lights indepentenly. I also want a dim and a menu to change the color. I like it how it is with group devices but canât get that for the color and temperature.
This is on desktop. On mobile I see the version with only colors but want something like the top. Is this even possible or do I need to use a different solution.
On Mobile I need to select
Color Temperature(+ checkbox real fields) and Hue(+ checkbox real field.
Itâs bugging on mobile but I see both fields. On Desktop I only see this
But Iâm unable to select the colors. On mobile I can select colors but the temperature will still be highlighted and you see flashing images of the temperature when you are on the colors.
(When you didnât already) Afaik youâll need to add all numeric values of an RGBW light + the light mode.
The device class should be set to âlightâ.
(Check the Device settings screenshots below)
I think Iâve missed the checkbox in the List block. I feel so stupid for take your time. But Iâm happy thatâs finally solved. This is a perfect solution for the Hue Beyond. That has 2 lights one down and one top and now I can control it with one device in Homey.
