[APP][Pro][DEPRECATED] We Connect / myAudi / MyŠKODA / My SEAT / My Cupra
No problem. Better to mention it. Otherwise I might forget :sweat_smile:
As it happened to me yesterday the following might also be a nice to have. if the charge plug is connected but is sensing no voltage (In the we-Connect app it states no power). That way a automation issue with the charger can be detected as well :+1:t2:
Hmm app stopped refreshing data
Error report created
445a4d21-56bc-4e7d-9a63-3f91c56a4274
@SvenRhein Will check
Working on the app today :slight_smile:
Thx @martijnpoppen and Happy Easter
@SvenRhein Not seeing errors in the logs. Can you take the following steps?
  • restart the app.
  • press force refresh
  • wait 3 minutes
  • send a report
@zakraket Did check. But not seeing any errors for this :confused:
  • restart the app.
  • press start charging
  • wait 3 minutes
  • send a report
New app update (test: 0.8.0): (auto update only)
Changelog:
  • NEW: prepare for Homey 7.4 (promise rejections)
  • FIX: Audi E-Tron (55 models etc) - plug connected @Harry
  • FIX: Plug connected flowcard
  • FIX: token refresh - (edge case when first try fails)
  • FIX: Set Temperature - Flowcard & UI
  • FIX: Has changed trigger cards
  • FIX: Skoda IV Enyaq - charge time in minutes instead of seconds
Done
btw. in the Audi app there is a “Modus Direct laden starten” which starts loading, but to stop charging I need to select “timermodus starten”. Maybe that’s usefull info.
Maybe there’s some other parameter that needs to be met to be able to start charging?
“chargeplug connected” still does not seem to fire with update 080
Is it possible to download the app and how?
Hey @ThomasD
Currently the app is in development. Every now and then theres a app URL for testing.
Hope to have this app live within 2 weeks :slight_smile:
Hi Martijn, FYI, will test today afternoon, however I guess you did (or not?) fix the “The temperature has changed” ? If so, it’s not working still :frowning: If you did not, don’t worry then.
@Sharkys I tested it and it worked…
Strange thing is, the temperature card is a default Homey card… :confused:
You’re trying the outdoor temp card right?
Tested again
  • restart app
  • put power plug in car
  • no trigger on power plug (received a trigger on the mileage in the meantime)
  • restart app Homey app
  • force refresh in Homey app
  • pressed start charging in Homey app
  • wait 3 min
  • checked audi app (incl. refresh)
Nothing happens, send another diag
(started charging in audi app using “Modus ‘Direct laden’ starten”)
btw I checked your todolist; Audi Hybrid a3 also always displays 100% fuel
…well :slight_smile: …I’m using this, so I assume it’s outdoor :
obrazek
But I see also :
obrazek
Anyway, I assume it’s this value :
Btw, just as you can see, value got updated few seconds ago and nothing has been triggered.
Again it’s not critical issue/functionality but it helps with testing at this stage…
Diag if it helps : 5e6885ef-7592-4f5d-81da-c843e6d49782
update Btw, seems that “less then” is working just fine…
Hmm I’ll check if I can override those cards. I’m using Homey compose + custom logic to create the division per car.
Seems like the predefined cards don’t like that :stuck_out_tongue:
Will this app also be able to control when to charge the car according to cheap power prices?
@Kongedam yes if you have another app which is checking the prices
Hoi Martijn,
The buttons start/stop charging and start/stop air conditioning and start/stop ventilation doesn’t still work. Either change temp. Got any response from the enyaq also loading km doesn’t change either. Sometime’s the value change and a another time not.
Hi Martijn,
I can see the value for Powerplug connected now and the value is also updated, but it doesn’t trigger the flow.
Regards,
Harry
