[APP][Pro][DEPRECATED] We Connect / myAudi / MyŠKODA / My SEAT / My Cupra
@Harry can you send a diagnostic report? Looks like you’re missing data indeed.
Hi Martijn,
Report is created.
71160b3f-0149-4c89-af89-e4206f8bb74a
Regards,
Harry
Can I help anyhow with debugging this Martijn ? The problem is that values get updated and the flow with single trigger and no additional condition is not executed… but the range is triggered regularly.
I also wonder if anyone else can confirm it’s working or not.
That is strange…
Which cards are you trying?
Maybe I have a typo somewhere
Helping debugging is quite hard I think, I forced the change via code. and that worked… But it should also work on a value change
Do you mean this ?
obrazek
obrazek
But it’s true that this is not TARGET temperature nor OUTDOOR temperature…and for Plug connected, it’s written "P"onnected … but I don’t think this is the case, or ?
I was just testing this to see frequency of updates, naturally I would be using triggers “becomes less/greater then” …
yes that’s a typo in the title.
I’ll check the ID’s
Temperature should be the default homey card.
Will add it to the list. :slight_smile:
Got some crash reports in my mail. Investigating it :slight_smile:
My car is still updating, althought very slow, roughly every 2-4 hours (I have the setting on 20mins) when I check the outside temp. I will be driving this afternoon, so I will test triggers for chargeconnector and mileage.
Btw the 2-4hours updating is fine by me, I’m not planning to do anything with outsidetemp, and as long as I get an update on the mileage at some point that’s fine. I just want to be able to start/stop charging (and maybe climate control, that already works)
New app update (test: 0.7.10): (auto update only)
Changelog:
  • FIX: app crash
Hi
Yes, I did. Didn’t work, unfortunately.
Do you think the app will ever support starting the heater on my model!
5fd982a4-5b20-4545-9054-0b057c21d389
Med vänlig hälsning,
Bo Björkman
@Bo_Bjorkman not sure have to debug that.
Ok, thank you.
Bo Björkman
Hi Martijn,
I got an ID4 and I would be very interested in yr Connect App, but i cant find it in the Homey App environment. How can I get hold of it?
Thnx in advance,
Marcel.
Hey @MCoelman
Currently the app is in development. Every now and then theres a app URL for testing.
Hope to have this app live within 2 weeks :slight_smile:
I was able to test some things:
  • “mileage” updates, and my flow triggers on the mileage changed
  • “chargingplug connected” updates, but the flowtrigger for that does not trigger. The update comes quite late, and not at the same moment as mileage update
  • still nothing happens when I try to manually start/stop charging after plugging in the car with a low battery
    Sent a diag
Thanks! will check :smiley:
Batterylevel also updates, fairly good (my homey A3 is set to 20min updates currently)
Left two red squares are 2 15min drives (from home (17:45-18:00) and to home), the right is charging from low level to 100% (car is programmed to charge between 1:00-6:00 and takes around 2-3hours)
The app shows the charge plug connected and disconnected as expected however the flow card if disconnected or connected does not start. The flow card that gets triggered if the KM traveled has changed does work and also the and is connected card.
@bug yes
I’m aware and it’s on the list :slight_smile:
Should look at the list more often :eyes:
