[APP][Pro][DEPRECATED] We Connect / myAudi / MyŠKODA / My SEAT / My Cupra
Hoi Martijn,
I can share my car with you. What do you needed?
Donated some money for your great work @martijnpoppen!
Feature to maybe add to you long list :wink: the charging speed (i can see it in the app, so assume its in the api), would be great!
Thanks a lot ! :smiley: appreciated
Yes wil add it to the list :smiley:
It’s possible and we can add it to Homey insights too
New app update (test: 0.4.5): (auto update only)
Changelog:
  • FIX: issue with refresh data
So I think I finally fixed the issue where the app becomes stuck and can’t update the data. :ok_hand:
I will test and report
New app update (test: 0.4.6): (auto update only)
Changelog:
  • FIX: AppCrash => DeciKelvin to Celsius conversion for target_temperature @SvenRhein
@martijnpoppen looking better every iteration :star_struck:
my notes: charging button returns “type is not defined” on the Golf GTE.
the pre-heating/cooling shows 22,9 (both values) in the app and 23,0 as the set temp on the web client while current temperature is 22,90. i think the floating calculation is the issue there :wink:
Great work so far !!
Will alter my decikelvin to Celsius calculation :slight_smile:
Hi
What is iobroker? Do I need it to make your app work? I have a VW Tiguan 2020 and I can’t any information from my car. Thanks for your work!
@martijnpoppen I just wonder, would it be possible to enable also login with combination of phone number and password ? On VWIdent pages you can choose between email and phone number, when you choose phone number, it will generate code but you can skip it and enter password instead. It might help as backup solution for cases like mine due to the “throttle” error VW is trying to resolve already for week while the phone login works still fine. Just in case it’s “easy” to implement but on other side this “backup” option might work also others in the future. Thank you.
And you have WeConnect paid and you see state of your car in the official VW app, right?
If this is the case, you may want to share diag.log with developer or Martijn might contact you for other ways to share some info.
ioBroker integration is kind if platform independent solution for the times before Martijn start developing his app - search for WeConnect ioBroker on the Google…
No, you don’t need it. It’s another iot platform.
Martijnpoppen uses it to get extra information as the implementation there is mostly done.
Hey @Bo_Bjorkman
At the current moment the app is in testing phase.
So the test link I get from Athom will be overwritten a lot of times.
When i have a new test version up and running i’ll put the link here.
Tiguan 2020 is supported al should work
@martijnpoppen , the latest version of the app has crashed a couple of times. Mostly when I want to add / remove the start climate controll buttons. After saving and returning back to the main menu the screen remains black. Closing the homey app and starting again will solve the issue.
This morning is noticed that the app is not available. Had to reboot my homey.
All the values looks good in the app. I am still struggling with the climate controll. I don’t get it started from homey. But if i start it from the Audi app and then press multiple (random?) climate / ventilation buttons it stops the climate controll.
So there is interaction. I will try to reproduce it to understand which buttons are triggering something.
Have you shared diag. logs please?
Can you explain how to download these? Is this via the webgui or homey app?
I think I have found the option. Ingot this code
dcc80cdc-e983-415a-9213-cf13a0386fc9
When the app crashes.
You can go to the app and send a report.
When you reboot the app or Homey the log is gone
Good to know, next time i will create a report before the reboot.
Is the link freely available?
I’d like to use the app with my ID.4….:pray:
