[APP][Pro][DEPRECATED] We Connect / myAudi / MyŠKODA / My SEAT / My Cupra
Then this app would also break.
The thing is. All the apps on github which are VAG apps are based on the IObroker or inspired by.
Seems like the IObroker adapter is the best solution to go with. Also to get all the new features. Next to that the community behind that adapter is quite big
Strange.
As the fix I made should update the data :thinking:
That was the whole Idea of this update
My data gets updated now. So not sure what goes wrong on your side.
Edit: theres an error in your log. Will check tomorrow :slight_smile:
That is fair enough, was just a bit curious about the advantages and drawbacks. :wink:
So i just came home after a small drive and I can confirm my changes are working :stuck_out_tongue:
Updates are coming trough
@Sharkys I’ll DM you later today to do a check :slight_smile:
New app update (test: 0.1.7):
Changelog:
  • FIX: prevent crashing when data unknown → Fix for VW GTE @Bug (think you also shared the report?)
  • NEW: add VW ID3 battery and range status - @Exile82 @peltsi51
If you have the test app installed then you would be able to test. Otherwise the update will come on monday with a test link :slight_smile:
Question:
Is someone willing to share their VW with me? :innocent: (Then I can test with live data.)
It will speed up the development process and I won’t have to go trough IoBroker json files to check the statuses.
I have VW ID.4, how can i help? Login info on we connect id app?
@martijnpoppen i did send a report in as well.
The things that are showing are not all the correct values but I am receiving values and that is a good thing to begin with.
Oil 0% and fuel 100% while range is 0KM.
Battery SOC is showing and that is a cool thing.
The oil change is not showing correct data and I wonder if all values that are received from the API pull request could be found in variables that could then be used in flows. (To update virtual devices for instance)
Cable connected would be one of those and charging would be another along with turning on the car heater to a temperature or the window heater on or off.
I send you a separate DM for the car app info
:heart_eyes:
@Ruben_Rosland if you’re willing to invite me as a user would be helpful. :slight_smile:
If you want that I’ll DM you
Yes
Theres is quite some mapping which needs to be done.
But when I get the shared accounts it Will be easier :slight_smile:
Seems not to work for the moment.
I would feel quite confident with lending you access to my car for testing…
Sure​:+1:t2::blush:
Same here with ID3, no measurements available. If you don’t get any other to share their car please PM me.
how do I use ioBroker?
Is there an instruction I can use?
@peltsi51 I got a ID4 already. I think it Will be the same as the ID3
@AndRacer not really. And I see that the Cupra is not supported yet :confused:
@martijnpoppen
No more app download at the test-channel available?
@Tregobad :point_up:
Monday again. As every new update has to go trough to Athom certification. Because It’s not live yet
If you could make that available for flows that would be great :+1:t2:
If arrived home
And is home
Would help a lot.
@Exile82 @peltsi51
Can you share some screenshots of available data in your we-connect app?
Seems quite limited for the ID4.
Non ID cars do also have:
  • Driven kilometers
  • Inspection in x days
  • Inspection in x km
  • vehicle moving
Missing this kind of info for the ID4. But not sure if every ID is the same, so just checking. :slight_smile:
