[APP][Pro][DEPRECATED] We Connect / myAudi / MyŠKODA / My SEAT / My Cupra
@Sven_311 see 2 posts above yours :wink: [APP][Pro] We Connect / myAudi / MyŠKODA / My SEAT / My Cupra - #2972 by martijnpoppen
Here you go :slight_smile:
90a748d6-4e5a-4aff-ab56-b80771a3a6a1
@A.Hallberg can you make sure to enable debug in the device settings so I can see a bit more data?
Do you need more data? the updates does not work for My Skoda since 4 days :frowning: do you want debug for my car aswell?
@Emil_Linder you can send a report
However Skoda is already broken for a longer period. The post above is about Audi
There’s not much I can do if the api is changed. I am dependant on another SDK and I can’t reverse engineer this myself
I have noticed that for my Audi for some while the climatization does not work (only thing I use at the moment). I can use my audi app remotely to change things.
Anybody else having challenges as well?
Is there a way to check where this is going wrong?
btw, s-pin was added some while ago
@Patrick_Van_Deursen Audi API has issues as mentioned above
There’s not much I can do if the api is changed. I am dependent on a SDK and I can’t reverse engineer this myself
Do you have the link to the sdk?
@Emil_Linder GitHub - TA2k/ioBroker.vw-connect: ioBroker Adapter for VW We connect and Skoda connect
This is the only integration I found (when i was building this app) which includes all 5 brands.
But as you can see there’s hardly any activity there. Also asked the dev if he can give me pointers in how to reverse engineer it so i can add changes, but never got a response on that
I’m looking into alternatives but they seem to be paid or limited though.
Athom is also trying to get in contact with the manufacturer of the VAG API. So hopefully that will work out.
Hi.
Afer upprade the ID Software in my care VW ID.4 GTX i get error.
It seems that the API has been updated / changed / does not work after the upgrade.
Has anyone else reported the same?
Has VW released any documentation about the changes?
Br Rolf Bredesen
@Rolf_Bredesen what error are you talking about? I only see a screenshot of your timeline
Hi Martijn,
Since over a day my vw app does not update the cars data anymore and is not connected with it (I cannot control it nor does the information update). What can I do to fix this?
Best wishes
@KoenvdL Please logout and login again in the VW app on your phone and accept the new terms and conditions
Awesome, that did the trick! Thanks for your quick reply. I love the app and use it a lot :+1:t2::+1:t2:
Hi
After upgrading ID4 to 3.7 i lost communication from Homey to my car. Even though it says I was connected, the Homey APP did not update. VW writes that the API have changed. I use Homey
to control my charging as well for other divices. When cabn I expect to be in control again ?
Where do you see that?
And read the 2 messages above yours, there you can see the solution
OK, saw that now. I did not get promted for new terms.
@Uffe_Rasmussen can you try this url? https://identity.vwgroup.io/signin-service/v1/signin/a827267f-6cc8-4b02-a178-3205b06a6210@apps_vw-dilab_com?relayState=ce0c84223d95b23890e3ec025b5a35ec7827facc
Ok this is on my pc and the web side. I can login, but i am still not getting promted to accept any terms or ?
@Uffe_Rasmussen then please send a diagnostic report
