It’s cool that you want to share, but maybe this is the wrong topic, as that dashbord is from a different app?
Or is your objective to have people switch to a different subscription based app? ![]()
No. I honestly was mistaken. I use both dashboards so I follow both threads.
Since i can not stream your dashboard ( I have an early 2018) to my nest I also use the other one.
But not on HP2023 - nor IP or host name works.
Hello, just stumble upon this, looks great. But i must have missed something. i have a pro 2019, i add a new dashboard but cant add anything. its like it dont find any of my devices.
EDIT, works now, just took some time to load it all
EDIT2: you dont need the app for the old homeys? i installed it but dont know what it does exactley?
First time you login has some loading issues that I haven’t looked into. A refresh usually does it ![]()
The app is required if you want to store the dashboard somewhere else than in that exact browser. In the native Homey app, add a device of type Dashboard and give it a name. This will then show as a separate dashboard when you open homeyboard.github.io. Any changes to this dashboard will be available everywhere you open this dashboard ![]()
No way to do this yet. As with everything else; I’m working on it ![]()
A 70" screen should do it ![]()
where can i find all the icons that are availble ?
im search for something to add for my 65% dimable lights
but i dont know how i can search for that in english ![]()
Nice work!
Unfortunately I haven’t figured out how to configure devices, like switches.
Insights works great and so do sliders.
How do I get devices to work?
Devices is actually just there to be backwards compatibel. You should add capabilities, as this is the actual controllable entities “inside” devices ![]()
But @skogsaas, but adding a random device first, you get a nice icon and headline for the widget ![]()
Hi! Great app, love it.
I would like to have the ability to offset insights +/- hours. Specific need for me now is to offset 2 of 5 insights in same view with -1 hour to align values from “Power of the hour” previous hour cost and consumption, with some actual consumptions and price. As you see here 2 of 3 insights are off by one hour.
Welcome Frode! (your first post to the forum) ![]()
Yeah, not really possible with Homey Insights ![]()
When I give you the option to select Last 6 hours, I actually send the string last6Hours to the Homey API. I don’t have any option to request anything else than the options I present to you. I can add an option to adjust the time when it’s returned though ![]()
Added it to the list: INSIGHT: Option to add time offset to returned series · Issue #132 · skogsaas/homey.dashboards · GitHub
Perfect.
You are doing a good work. Stå på ![]()
Hmm… weird ![]()
I’m guessing it has something to do with threshold being below the graph axis minimum value.
Added it to the list: INSIGHT: Base color used when graph min-value greater than threshold · Issue #134 · skogsaas/homey.dashboards · GitHub
It’s not typically something that would be detected in Norway at the moment ![]()
@Morgan :
maybe you can help me, trying to follow your steps. I got the widget in Bing AI Search, right clicked, inspect and get the following picture. where to find not the iframe you are referring to?
Thank you
@Peter_Kawa : Any Idea how to get the current location to be determined?
I use the following settings:
and the result is:
thank you
Most probably you’d enable these options:
The code I used (I entered your city code of Heidenheim … ):
https://dayspedia.com/if/digit/?v=1&iframe=eyJ3LTEyIjp0cnVlLCJ3LTExIjp0cnVlLCJ3LTEzIjp0cnVlLCJ3LTE0IjpmYWxzZSwidy0xNSI6ZmFsc2UsInctMTEwIjp0cnVlLCJ3LXdpZHRoLTAiOnRydWUsInctd2lkdGgtMSI6ZmFsc2UsInctd2lkdGgtMiI6ZmFsc2UsInctMTYiOiIyNHB4Iiwidy0xOSI6IjQ4Iiwidy0xNyI6IjE2Iiwidy0yMSI6dHJ1ZSwiYmdpbWFnZSI6MTMsImJnaW1hZ2VTZXQiOnRydWUsInctMjFjMCI6IiNmZmZmZmYiLCJ3LTAiOnRydWUsInctMyI6dHJ1ZSwidy0zYzAiOiIjMzQzNDM0Iiwidy0zYjAiOiI0Iiwidy02IjoiIzM0MzQzNCIsInctMjAiOnRydWUsInctNCI6IiMwMDdkYmYiLCJ3LTE4Ijp0cnVlLCJ3LXdpZHRoLTJjLTAiOiIzMDAiLCJ3LTExNSI6ZmFsc2V9&lang=nl&cityid=29812
You’d be able to open this url in your browser, it should show the clock.
What I did, I stripped this leading <iframe .. > part from the code:
<!--Dayspedia.com widget--><iframe width='210' height='340' style='padding:0!important;margin:0!important;border:none!important;background:none!important;background:transparent!important' marginheight='0' marginwidth='0' frameborder='0' scrolling='no' comment='/*defined*/' src='
and I stripped the trailing </iframe> part from the code:
'></iframe><!--Dayspedia.com widget ENDS-->
Thank you. But is there a way to show a dynamic location of my device?
Scenario is in a camper
