I have so many important flows running with Fully enabled that I can’t deactivate them for an extended period. I’d be happy to show you some simple flows, but I think you already know them.
This is a separate flow that is triggered when someone recognizes it, but I am not at home.
These flows are started by Alexa.
I also bought Home Assistant. I have Fully Kiosk installed there as well, and I now create many flows there.
I’m not having any more problems turning it on. You see, it was turned off at 6:43 and turned back on at 16:34.
Hi Heinz
I might be completely wrong, but I think I read here in the forum, regarding the structure of Flows: The “If” card as a trigger must always have a status change. For example, if the motion detector detects movement… then…
In your first Flow, I don’t see this status change in the “If” function.
If tablet is switched on… (the change here would be that the tablet is switched off…)
Perhaps I’m completely wrong; this is just a guess on my part.
The first automation works perfectly. The tablet switches off after 1 minute (Android screensaver). If it is woken up by movement, the IF condition is met.
Okay, then I’m afraid I can’t be of any further help.
As I said, Dashboard Controller and Fully Kiosk are now running perfectly on my tablet. I switched from the Fully Kiosk single app to the browser.
Since updating Homey to version rc15, the app has stopped working. It crashes after a few seconds.
4d324e4f-6a25-4942-9a14-eebf856f05af
Thanks for the notification, but I’ve heared from other developers that their apps also suddenly stopped working for rc15. So probably an issue within Homey itself. So I’m waiting for a new rc before I start debugging it.
Das gleiche Problem mit rc15 bei mir
Und rc16 hat es behoben
Hi.
im having trouble with mij chatgpt using homey flows.
in that investigation my chatgpt stumbled on this.
i hope this is usefull information for you?
greetings marco
