[APP][Pro] Connect Solar Goodwe Inverter to Homey
Sad to hear… It works fine (almost) for me. Can you see the data at the SEMS-portal?
Yea. And in Home Assistant. Just not Homey
same issue here, I have 2 inverters and can’t see the data from the second inverter.
Follow this 2 guides, then you can get the data into the homey energy.
Hey guys, I’m in Perth and I’m also having issues in connecting to my GoodWe SEMS cloud. Did you manage to find a way to get it to work in the end?
Hey mate,
Did you end up getting it working in the end?
I’m in Perth and I’m having the same issue.
Hi @Andre_Aucamp no, I’ve retried a few times over the last few weeks but it’s always the same issue.
I can only assume that something about the Aus set up or protocols means the login string is slightly different to access the SEMS+ cloud. Although that just seems really odd.
It’s likely to be pretty simple to fix from a code perspective (if there is malformed request) but without viewing the code to see what is being passed in the login request, there’s no real way to work out what part is failing.
Unless someone can point me at the code base to review (I haven’t figured out how to find this, is it in GitHub somewhere?) then I’m stuffed too.
Samenproblem here, cant get any data from the goodwe inverter (goodwe cloud) Sems and Sems+ are working fine, but no connection via Homey, someone an idea what to do?
Last year it worked OK, so something has changed during the latest updates I guess
Is there more information about his? It would be great if you can switch on or off, or set a temporary grid limit in some cases by using flows
GW10KN-ET + Lynx F13.1-H, Cloud, SOC OK, Power = 0 W, no Energy tile.
Dear Michal,
Could you perhaps add another function to the Goodwe app?
There should be an option to start/stop the inverter or reduce its power via API.
with regards
Jan Hendriks
Is someone experiencing an issue with logging into the app adding the solar inverter? Keeps sending me the same error although the credentials are correct.
Assuming you also have an Goodwe phone app: does it still show data?
when you logout, can you still login to that one?
GoodWe phone app is working fine after logging out and then logging in, no errors. In the Homey app, I can see my inverter after adding it as a device, but no data is shown after that.
Where are you based @labmarko ? Reason being, several people in Australia have the same issue as you, and it is not resolved afaik.
Could be a red herring or coincidence, but I’m also 100% sure of the login credentials and get the same issue as you. Shame.
Yes, it is a shame. I am based in the EU, not Australia, and it is working perfectly with HA. I can’t figure out what I am doing wrong with Homey, as the inverter is recognized at the beginning of configuration.
Well it’s interesting that it appears to ‘break the pattern’ I thought we maybe had. Perhaps there is something related to certain models instead.
My model is GW15KAU-DT, what do you have?
I have the same problem. I tried to connect 2 Goodwe’s GW20K-SDT-30 just like the manual, but no data in Homey. Sems portal and the sems app/cloud works both fine. Is somebody else having the same problems with this inverter?
EDIT: Working now. I do not exacly know how but it seems ok.
@Michal_Stranik
Dear Michael,
I have a problem with the Energy tab of my Homey and the Goodwe Modus Battery. In this/your app you used “meter_kwh_charging” and “meter_kwh_discharging”. The result is that the Energy tab gives no result in the battery part. I have contact Homey for that problem. The answer they given is to use these names:
“The capabilities should be: “meterPowerImportedCapability”: “meter_power.charged”,
“meterPowerExportedCapability”: “meter_power.discharged”.
Can you provide these changes into your app?
Thanks in advance.
Kind regards, Justus
Anyone familiar with a Goodwe-HA-Homey setup that enables me to reduce power (variable) and/or turn it on/off?
I have it fully integrated without a HA workaround in homey with my SolarEde SE9K:
  • Price positive: 100% power
  • Price negative: power is reduced to the amount I use
  • Price inc tax below zero: power to 0% (and turn on all heaters … kidding…)
Since this great app unfortunately does not yet include controling the inverter in any way. I.e. set power limit or turn it on/off. (Although you can control it directly with the SolarGo app.) I’d love someone to share a working software setup using any workaround.
Thx in advance!
