[APP][Pro] Connect Solar Goodwe Inverter to Homey
Thank you for the quick updates!
Homey is getting data now:
However, it’s giving only power data of the individual strings, no total solar power. This means it does not automatically show data in the energy tab. Also, the (minimum) refresh update is 5min, which is quite large. Is this limited by the cloud connection?
See my diagnostic report here: 2e498c94-27c8-4c56-b722-c68346969cc7
Goodwe GW3000D-NS
Thanks for the quick fix for outputV, but I have the same problem as Joram.
Vraagje aan jou,… geeft hij je zonne-energie opbrengst nu ook weer in homey energy?
Bij mij geeft hij in als ik op het apparaat klik wel een waarde bij de strings (string 1 2100w en dit klopt ook met de app), maar bij zonnestroom staat 0) en in homey energy geeft hij ook niets aan, terwijl uitsluiten van energie op nee staat bij de omvormer….
misschien ben ik te ongeduldig heb de inverter net weer een paar minuten in homey staan, na update 1.15.3
hoor graag van je
No more outputV errors! Thank you!
Other than that I have the same issue as others; String 1 reports data, but ‘Zonnestroom’ stays at 0.
Same issue here unfortunately
Reported as: c143f982-69d6-47ac-99e5-08c6740defad
With: GW4200D-NS
Just noticed version 1.15.4 but this isn’t the solution as well…. Total solar power doesn’t show, so the inverter isn’t working for homey energy…
I have 1.15.4 as well, no issues here. Both strings are showing power. Also zonnestroom is visible. There is only a slight difference in zonnestroom en vermogen. Since everything is up and running again, the totals are showing in the energy tab. If needed I can share a diagnostics report.
Dug into the cloud issue a bit — found the root cause.
My account is on GoodWe’s newer SEMS+ backend (semsplus.goodwe.com), not the classic SEMS portal — confirmed via the station ID in the SEMS+ URL matching my system exactly. I tested the SEMS+ Web API directly (login + telemetry/telecounting endpoints, same auth flow as the recent SEMS+ PR in TimSoethout’s HA integration) and here’s what it actually returns:
  • PV power comes per-MPPT only: MPPT-1:Ppv and MPPT-2:Ppv (kW) — no combined “total solar power” field. Has to be summed, same root cause as the earlier Modbus total-power bug.
  • status is a bare numeric code (e.g. 5), not a text label — that’s probably why “Status” shows N/A, no code→label mapping for it.
  • There’s genuinely no load/consumption field anywhere in the SEMS+ response for this inverter — it has no smart meter/CT clamp, so “Belasting” can never populate via cloud for this system. Not a bug, just missing upstream data.
Everything else (PV strings, AC voltage/current/frequency, temperature, operating hours, energy today/week/month/year/total) comes through fine.
That explains a lot, my account is also migrated to SEMS+ due to a notification saying the classic sems will discontinue. Would a local modbus connection solve the problem. Or can the Homey app possibly combine the strings into the total solar power?
Local Modbus is always preferable. Since you are not cloud independent, you should try it.
make sure you install the latest test version
Update to v1.15.5 and send a new diagnostic report:
If your GoodWe cloud device was showing “Cannot read data from GoodWe cloud” or missing values (e.g. total solar power, firmware version), please update the app to v1.15.5 first.
This version no longer takes the device offline just because one field (e.g. outputV, firmwareVersion, SOH) is missing from your account’s data — it now shows whatever values it can read and simply logs the rest, so partial/unusual data from GoodWe’s cloud won’t break your device anymore.
It also now logs the data GoodWe’s cloud sends back for your inverter. So if something is still missing or wrong (e.g. no total solar power) after updating, please:
Submit a new diagnostic report from the app (Homey app → GoodWe Inverter → Settings icon → Report a problem), and post the Log ID here.
That one report should now have everything needed to fix it — no back-and-forth needed. Thanks for your patience!
As requested: 524fe2b9-9cf5-41a5-afc5-20556d2200f7
7ef809f4-82a7-4959-8212-c708bb29add5
Still the same issue
Thanks for all the work you put into it!
jeroen welke app gebruik je. De GoodWe Omvormer laat niet veel zien. Ik gebruik nu de GoodWe SEMS app van Wisse Koelman. Deze is niet zo uitgebreid als de GoodWe app maar laat wat je opwekt aan vermogen en totale opbrengst van vandaag zien. misschien heb je hier voorlopig genoeg aan.
M.V.G Peter
Same issue here, no values for solar power since the SEMS update. Installed the 1.15.5 version.
342ea1cc-285a-48df-ba8c-d0fd454b1a21
Thx for your efforts!
I’ve pushed a fix for the missing total power / voltage issue on your GW4200D-NS. Please install the test version here:
After it updates and polls at least once, you should see:
Vermogen (total power) populated again, using the inverter’s own reported output instead of the missing powerflow data.
Voltage now read correctly for your single-phase inverter (it was looking for a 3-phase field your model doesn’t send).
firmwareVersion and SOH will still show - — your inverter doesn’t report those at all (no battery, and no firmware field in its data), so there’s nothing to fix there.
Let me know if the numbers look right, or send another diagnostic report if anything’s still off.
Thanks for testing! Looking at your log, it looks like this was still running the previous version — could you make sure you’re on the test build?
Your inverter (GW3000-XS) is reporting 296–887 W of output in the data GoodWe sends, so once the test build picks it up, total solar power should show up correctly in Homey Energy. If it still shows nothing after updating and one poll cycle, send another diagnostic report and I’ll take another look.
This fixes it for me. Thanks so much. Homey is great thanks to people like you
Now its working again, thanks!!
It was running the test version!
But now I added the 1.15.6 version and this is doing great!!! Problem solved!
Thanks!!!
