Hi again, do you know if it could be possible to use hostname instead when adding a device?
I use dnsmasq as both dhcp and dns, and it gives my devices a automatic hostname, for example shellyplug-s-B4DBB6.lan, that I can resolve on all vlans.
I tried and I can test successful and connect the device but then it is immediately unreachable with the following error message: ârequest to http://shellyplug-s-B4DBB6.lan/status failed, reason: undefinedâ
I rebooted and did a diagnostic: 13c50223-ca4a-40c8-bae2-bbe706f5829a
Does accessing the URL from the error message returns the expected JSON output from the device? The error log below does not indicated much more that it fails with an undefined error. It looks like Homey (or more specific the node-fetch package is unable to resolve the address).
Note: this log has been manually submitted by a user.
Log ID: 13c50223-ca4a-40c8-bae2-bbe706f5829a
User Message:
Added device with hostname
---- stdout ----
2021-02-03 16:17:15 [log] [ShellyApp] Initializing Shelly App ...
2021-02-03 16:22:44 [log] [ManagerDrivers] [shelly-plug-s] [0] FetchError: request to http://shellyplug-s-b4dbb6.lan/status failed, reason: undefined
at ClientRequest. (/node_modules/node-fetch/lib/index.js:1461:11)
at ClientRequest.emit (events.js:311:20)
at Socket.socketErrorListener (_http_client.js:426:9)
at Socket.emit (events.js:311:20)
at emitErrorNT (internal/streams/destroy.js:92:8)
at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
at processTicksAndRejections (internal/process/task_queues.js:84:21) {
message: 'request to http://shellyplug-s-b4dbb6.lan/status failed, reason: undefined',
type: 'system',
errno: undefined,
code: undefined
---- stderr ----
Added trigger flowcard for when an overpowered event takes places for the devices Plug, Plug-s, 1PM/L, 2, 25, Dimmer, 3EM, EM, RGBW2Color and RGBW2White
Love the FW additions, have some additional requests though, can you make a flow card with update all firmware too? Thatâs what I usually do when the Shelly iOS app has a new fw. Just update all at the same time.
Where can I find the condition card, is that a card added to the âandâ section? How I see it, and correct me if you donât agree, is I want a set time; letâs say 05.00 am. Then check for a new fw, send a message which devices have the new FW and which version number and after that update them.
It looks correct from a web browser. But I tried removing the device and add it again but now It wonât add at all, so maybe I was just lucky the first time. Iâll go with IP adress, no big deal as long as they are reserved in the dhcp.
This is a completely different approach as the device condition and action card that have now been added. Please submit a feature request on Github and Iâll see what I can do.
Iâm not getting any readings from my H&T. It adds ok and then goes offline after about 4 m. Then it goes online every hour or if a reading changes by 1C or 5%H. But my device in Homey has no reading at all. Have restarted the app with the H&T online and added it again a few times but no difference. Am I missing something?
If you know how to run the app from the command line with the command homey app run ([HOW TO] CLI install method) you could run the app and see if it detected on the network as CoAP device. And if it is detected, why itâs not updating the status in Homey.
The first generation battery powered Shelly device are quite flaky though.
Assuming you mean âwhen Athom will update Homeyâ: nobody knows (some people are expecting the new firmware âany time nowâ, but AFAIK thatâs based more on hope than anything else).
I Need Support!
Habe some Shelly Plug s Which Worked without any problem. Sinne yesterday Homey is showing one Plug s as unavailable.
I can See the Plug in the Shelly App, in Browser, but Homey does not.
I deleted the device and tried to add it again, homey shows me that he found the ip, but then canât connect.
I restarted all, homey, the plug, WiFi. No success
All other plugs are still connected.
Does anyone has an idea
