[APP][Pro&Cloud] Shelly
Shelly RGBW2, Shelly DUO RGBW or the Shelly Bulb RGBW? And on what firmware version is the device?
If you are unsure, look it up under the device inmformation.
the device information says: Shelly Color Bulb, firmware version: 20230913-111548/v1.14.0-gcb84623
Will most likely be fixed with the next release.
perfect, thank you!
Hi, I understand there were some issues in the past with the Shelly H&T sensor. I just can’t get it to work. Tried rebooting Homey Pro, re-adding the device to Homey and Shelly but still the same result. It works in the Shelly app but Homey Pro just doesn’t update.
Follow the troubleshooting guide from the first post.
I did but no results. I can’t even reach the device at its IP so I guess it just doesn’t work if that’s your answer. Thanks.
Describe the steps you take when pairing the device and what the actual result is. Saying it just doesn’t work won’t help you solve your problem. I’m pretty sure you haven’t followed the instructions properly.
I did everything according
Pairing instructions WiFi devices with Homey (Pro)
The result is that Homey Pro sees the device and installs it but after a while doesn’t update anymore.
The IP address in Shelly app and Homey Pro device advanced settings are the same. It seems something goes wrong with polling the device after a while.
I will run through the steps again.
Battery devices aren’t polled but only report their status on change. If you have could enabled as well, try disabling it. Could be the device isn’t fast enough to report the status to both cloud as Homey. And cloud has priority over outbound websockets.
All is this is off course assuming you validated the outbound websocket connection.
Hi!
I am looking into adding 4 temperature sensors with the same setup as you have here with the " Shelly 1PM Gen3 + Shelly Plus Add-On + 5x Shelly DS18B20 temperature sensors".
I have one question that you might be able to help me with, how does this look in Homey? Are the sensors added as separate units or are they all in one unit? I need to be able to know which is which and label them.
Thanks,
Fredrik
They show up inside a single device, based on the Shelly 1PM Gen 3. The add-on module is not shown in Homey (also has no functions).
Each temperature sensor is a separate sensor on the device’s sensors tab. As an example my five temperature sensors are shown as follows, with a generic ‘Temperature sensor #’ name:
You cannot change their name or oder in Homey.
However, you can create a virtual device in Homey based on the Shelly device and name the sensors as you like.
Note that in the web interface of the Shelly 1PM Gen 3 itself, you can change the names of each sensor. However Homey does not import those names.
Thanks for this!
Hi, I think I have messed this up. I have a Shelly Plus 1 that worked perfectly until today, when I could no longer control it from the Homey App, but it works well from the Shelly App. I upgraded FW, but no avail. Then - and this may have been a mistake - I removed it from Homey to reconnect it.
When trying to add this as a “new device” / “Any Shelly Wifi Device”:
  • First the Homey app discovers it, but then says it failed to connect (“this can be due to internet connection, fw,
  • Now it does not discover it at all (still working perfect with Shelly app).
  • I try to connect it manually with the right (static) IP address. Then it says "Cannot read properties of null (reading ‘data’). I tried 1st and 2nd gen. With and without uname/pwd.
Any thoughts? I realize I maybe shouldn’t have removed the device, but that’s a bit late.
Sounds like networking issues. Follow the troubleshooting guide from the first post.
Thanks and sorry - now it works again, should’ve checked there first.
Hi, I have some trouble to keep a Shelly Plus Uni connected properly to my Homey. I have a few other Shelly Uni older version that logs temperatures and they work flawlessly.
But one new Shelly Plus Uni only just works for a few hours at best, and then there is an error “Not found - device id xxxxxx”
I’ve tried to restart shelly app, device and homey and I’ve also deleted the Uni and re-added it and when I do it works ok but all of a sudden it doesn’t. It has stable Wi-fi and it does work in the Shelly app all the time. Anyone had the same problem? I use this Uni with 5pcs temp sensors since the new one supports up to 5 sensors and it is implemented in a few advanced flows to tweak a heatpump.
Could you post a screenshot from the error and send a diagnostic report from the app settings when this occurs again.
I have a Shelly 0-10v that controls a fan. But is not possible to class it to anything other than “light” resulting in this device is turning off when we are leaving the house. Is it possible to create this class option? Thanks
You are in luck, yesterday I added a “use at your own risk” advanced flow card allowing to update device classes of devices. Will become available with the next release.
