[APP][Pro&Cloud] Shelly
Good to hear and thank you for the donation … much appreciated … :pray:
no, the inputs don’t change when the lamp is switch on/off in a flow. But i guess the output is what is controlled when used in a flow. i want to trigger another flow with the second switch, not the physical attached lamp. the status of the two inputs can be read into homey right?
it was possible with the fibaro dimmer switch.
Ok, please submit a feature request in GitHub with the screenshot from the post above. I’ll look into it when I have more time.
I can probably add the first four triggers from that list. But what do the last three?
Seems to be if you switch on/off 2-3 times with a regular toggle switch. For momentary this would be pressed 2-3 times.
v1.17.2 - 2020-03-01
  • BREAKING CHANGES Shelly 2.5 Relay: The Shelly 2.5 Relay driver has been refactored to avoid double polling. This breaks the current support for these devices and requires you to re-pair your device. Sorry for the inconvenience.
  • Also other small fixes and improvements.
i’ll do. thanks.
honestly i don’t know what the last three are about. for me the top four are the most important.
Ok, I’ll add the first four then …
And thank you for the donation, much appreciated … :pray:
I experience the same Problem like “Kristoffer_Ottosson”.
I have 30+ Shellys in my house. I tried to repair one 2.5 Relay but with no luck.
red exclamation mark in the upper right corner. Tried to restart homey more then twice, restarted app several times with no luck. I also tried to reboot shell relay and reset the password.
Any ideas?
v1.17.3 - 2020-03-02
  • BREAKING CHANGES RGBW2 4xWHITE: The RGBW2 4xWhite driver has been refactored to avoid double polling. This breaks the current support for these devices and requires you to re-pair your device. Sorry for the inconvenience.
  • Added a toggle button for the RGBW2 Color to switch between white and color mode.
  • Added trigger cards for the Shelly Dimmer to trigger flows based on input 1 and 2.
Works now! Great app
with the new version v1.17.3?
After repairing two devices and updating app, all the red exclamation marks are gone!?
since the update today the connection with the dimmers was lost (“onbereikbaar”).
Strange is that when I refresh the app, the dimmer is for 2 seconds available and I can turn on the light. But after about 2 sec it is again unreachable.
removed the dimmer, reinstalled it but that didn’t change much.
Solved it by turning on dimmer in app during those 2 seconds and manually switch off.
Weird, I’ll check the code to see if I can explain this behavior and possibly fix it.
Even i have since the last update that the dimmer is unreachable
I see that release 1.17.3 introduced a bug in the Shelly Dimmer driver. I’ll fix that this evening. Please wait for that. If this issue persists on release 1.17.4 please submit a diagnostic report from the app settings and post the ID here on the support forum.
Thanks
v1.17.5 -2020-03-03
Fixes for trigger cards and missing capabilities for paired devices that may cause some devices to appear as offline (like the Shelly Dimmer).
Confirmed.
My Shelly Dimmer is working again!
(without having to re-pair again)
Thx @Phuturist!
My dimmer also works again. Thanks Phuturist
