Correct, just checked and that’s a bug. Might require you to re-pair the device after the next update.
I dont know how often tilt updates are send from the device. Do you see instant updates in the Shelly BLE Debug app?
thank you that this error will be fixed in the future.
I don’t know what you mean by the “Shelly BLE Debug App”. In the Shelly app is also a delay.
But the key point is that the card tilt changed has no function. After all, it is enough that a change is detected, even with delay.
So I could start a flow when the tilt is changend and greater from 45*.
I hope it is understandable.
Thank you very much
Search for it in the app store. With this app you can manage Shelly Blu devices, for instance upgrade it’s firmware.
Thank you for the information. Why do I need this app? I could also install an update to the Shelly Blue door Window via IOS using the Shelly Smart Control App.
The app allows you to see the actual values of the device with a direct connection between phone and device and thus eliminating other possible factors.
I am having the same issue and have gone through all the troubleshooting steps. It is a power plug that has updated firmware. I’ve rebooted both devices. I’ve made sure it’s awake, still get a white screen after clicking continue.
I had the same problem with a Shelly Plug S device
I had Homey pro installed in my 5GHz wifi network, and the Shelly Plug S is only 2,4 GHz.
Today I bought a Homey Network adapter, and it worked to add the Shelly Device at my first try.
My whole network is on the same subnet, så it is a bit odd, so if you dont have an Ethernet adapter. Try with the Homey Pro on a 2,4 GHz network
BR/Ulf
Hi.
Have several newly installed E27 rgbw bulbs that works fine, except for showing power consumption. I can see it in the Shelly app, but not in Homey.
Not sure why but I haven’t implemented it. Could you request it on GitHub so I don’t forget.
I’m using a new HOMEY PRO 2023 with Shelly App v3.21.5.
I’m trying to use Shelly plus 1 with add-on.
The pairing was OK.
I’m able to read the temperatures coming from external with DS18B20 probes.
But I can’t read the analog input of the ADD-ON in HOMEY.
While it’s OK with Shelly app.
It seems also that ‘input1’ does not reflect the input of the Shelly plus 1.
So, what is that ‘input1’ ?
Regards
Please explain further on what “cant read means” and send a diagnostic report from the app settings
This depends on the settings of your Shelly. Use Google or the manual on what the input of a Shelly device does.
You are right, I was not so clear …
On the ‘Input1’ issue : usually, when I press the switch connected to the basic SW input of the Shelly, I got this :
With the Shelly fitted with the add-on, nothing happen … It stay on ‘NON’.
On the ‘Analog Input’ issue, I do not see this input when I am writing a flow …
And, I do not see this analog input in the capabilities of this device :
While this analog input can be seen on the Shelly app on my phone …
I’ve tried to restart the HOMEY without any result.
I hope, these issues are now more clear …
Best regards
On the ‘Analog Input’ issue :
This input can be seen on the app Shelly :
Best regards
Could you post GitHub issues for both or them? It’s gonna be hard to fix since I can’t test this myself so better continu the discussion there.
I (thought I) solved this problem in the following way:
That worked for me.
But, the next day I found out that besides that the generated energy apears in the outer ring in the energy tab it is also shown as unknown usage in the inner ring.
So, still no solution.
Martin
first of all I’d like to apologize if this topic was already discussed - It’s quite busy threat. I looked but haven’t find this discussion.
My Homey sometimes get’s new IP address from DHCP (it doesn’t happen often, but it’s still annoying).
Seems, that when this happens all coms from Shelly devices is lost and devices needs to be re-added. Seems that update of Coyot settings of each device is not enough.
They add needs to be added again:
As it’s quite bunch of devices and there are lot’s of flows assigned to them - to recreate them is waste of time.
Isn’t there a way to reestablish coms between devices and app without re-adding?
(and please do not advice me to make reservation in DHCP and not change IP of Homey - I know that it’s best way - but sometimes it’s out of my reach)
Updating the CoIot setting in Shelly and rebooting the Shelly afterwards should be sufficient.
The battery view for the Shelly TRV isn’t working for me
It will update once the value is changes. Battery operated devices aren’t polled for their status.
I sent diagnostics to the developer and this device wasn’t currently included (U.S. Plug).
It’d be nicer to instead of saying “not good enough”, ask for any more info needed to say a device should be working.
