This is now live.
Since the update I get this error with my plus 1. All of them. I tried repairing as stated abobe, but this doesnt work. It will not find the devices automatically nor manual.
The initial error is too be expected. If you can not find the device make sure you have removed it before trying to add it again and itās discoverable (a setting in Shelly). Manually adding it wonāt find any devices. What does it say when you try to connect to the device manually?
Anyone experiencing similar issues? Iāve had an electrician over to replace some of my light switches with push buttons. Now everytime Iām pushing one of those new buttons, all (or at least most) the blinds are opening or shutting. This only occurs if I physically push the button but not when I switch the light on and off over the app.
The light is connected with a Shelly 1 and all of my blinds with Shelly 2.5.
m,n shelly 1 and 1 plus give interference after tonightās update how is that possible?
I canāt find the option to make the Shelly discoverable. Where is this option?
Edit: omg. Just noticed there is a new option for the plus 1. Before it was a combined one. Succeeded. Thank you.
Can we downgrade the app?
Have you actually read the changelog from the latest release?
Hi Jelger, has anyone reported that this is not working?
At the moment I use the http command insteady what works fine
Cheers,
Sven
Uh noāŗļø
OkĆ© thanš¤ i am not so happy on that
No, thanx for reporting. Iāll look into it.
since the latest update of the shelly app, homey becomes unresponsive⦠crashes, reboot and the cycle repeats. The only way to stop it is by disabling the shelly app when homey is booting.
Sounds like the issue below:
Not much I can do about it. I remember some people solved it by disabling thje Bonjour service on their Synology NAS.
thanks for the tip, ill give it a try.
Bit weird, it was working fine since yesterday.
Hopefully this is the issue and then ill bin the shelly
edit: indeed by disabeling the bonjour on the Synology the crashing stops. Its weird because until the latest update of the shelly app there was no problem at all.
Itās an issue with the mDNS implementation of Homey that sometimes affects users with specific network setups. It could very well be something changed in your network recently which triggered this.
It seems the mDNS implementation of Homey listens to mDNS broadcast messages even without the pairing wizard being active. With over 70+ drivers in the Shelly app and most have their own mDNS filter set up this requires resources. In combination with specific network setups Homey seems to choke on this. Itās been reported to Athom but they have decided not to look into this further due to it being a corner case scenario that only affects some users.
I have the same issues with my (only) Shelly 1plus. Since the app-update not working, app canāt find it (but itās online on itās fixed IP), and cannot find a ādiscoverableā option in the Shelly UI. I had to update to beta 0.10.0 (Shelly) also because on 0.9.3 the UI was very buggy (several things not working or stopped working after a few clicks). 0.10.0 seems to work okay, but no option to add it.
Where is the discover option?
I have the same issues. I removed the 1PMs from Homey, but I cannot add it again. It does not appear in the list, and when I want to add the 1PM manually with the IP address, it asks for the credentials. No idea where I can find the credentials, but when I use the access point username, but it does not recognize it.
It works fine in the Shelly app.
It would be helpful if the devices appear in the list when I want to add it again to Homey. Now, it is useless.
Didnāt find it. For me it was because at first it was a combined option and now there are two option in the app. Had to select 2nd generation. 2 were automatically discoverd. 2 via ip.
I was talking about the Shelly webui btw., I donāt use the Shelly app (If thatās what you mean)
But I donāt believe I did/changed anything, but my Shelly 1plus is now added again when I checked a minute ago⦠automatically (?) I tried to readd it throught the Homey app earlier but it wouldnāt find it.
Problem fixed now
