[APP][Pro&Cloud] Shelly
HI Have a question about the TRV app.
is Set the Temperature in flow the Room temperature or the target temperature?
and is it possible to set both kind of temperatures from the flows?
Thanks otherwise for a great app :slight_smile:
The room temperatuur is the measured room temperature. You can only set the target temperature.
Thanks for great app. Since a couple of weeks (probably last update) I had problems with my Shelly Dimmer 2:s. They do not turn on when a flow has “dim to” command. I have to also add “Turn on” with a delay to make them turn on.
Not a big problem but have to redo a lot of flows. All other zwave and zigbee devices also works as Shelly did before (they turn on with the command “Dim to”) and would be good if also Shelly did that.
I use Beta/Cloud and maybe the problem only is there.
I only turn on my lights with ‘dim to’ … dim to 100% is full on… dim to … random other value… . you probably know where i’m going.
So No, can’t say i recognize what you are saying.
I have it the same way but it does not work since a couple of weeks on any dimmer 2. The “dim to” in flow changes the dim value but it does not turn on any more.
Are you using Pro or Cloud? Latest FW on Shellys?
It’s probably an issue with the cloud driver. Support for cloud to cloud is very uncertain at the moment though. It might be removed all together. Probably more details on this soon.
Hello, how can i do to pairing manually shelly’s devices on my Homey bridge?
Thank you in advance…
You can’t. The Bridge is not involved when using Shelly devices, they must be connected to the Shelly cloud as the Bridge is not capable of accessing WiFi devices.
hello. I dont know if i write on good place, but i have big problem with all my shelly dimmers 2. For 1 year I did settings for all my shelly dimmer 2 (20 pieces). After 1 year when I need build these shelly in my electric cabinet I found a problem. Too Big reaction time. Problem can you see in attached videos.
too big responsive time with switch control. LED works immediately, but status in homey has latency about 30 seconds. What hat happens in 1 year? I have same wifi router Tplink mesh deco X60. I have last homey update 7.2.1 and shelly dimmer 2 last update too. before shelly update (with 1 year old firmware) was situation same long responsive time. So I think something is wrong hith homey shelly app. Can you help me please?
Thank you.
P.S. Shelly 1PM works complete ok with responsive time.
videos:
Read the troubleshooting guide from the first post in this topic.
Im not realy sure you are correct there
If I activate the url there I can send external temperature to the device… But for some reason It doesnt like when I send it to often… (I used my aqara temp sensor and sent on every temperature change and then the valve went with 0 degrees temperature during the night, so I got very hot in my bed room)
:slight_smile:
Ok. I understand what you mean now. There currently is no again card to set the external temperature measurement. Submit a feature request on GitHub so i won’t forget to add it. I’m away for the weekend.
Thanks for adding support for the Shelly pro 4pm. However, I noticed that for the Beta version (homey bridge) the pro 4pm is added as pro 4 instead, without power metering functions. Interestingly, I can add my pro 4pm as pro 2pm instead and get working power metering functionality for the first two channels. Any suggestions on how to get metering for all 4 channels?
Not a clue, I looked at the code and the measure_power and meter_power capability should be added even though the name might say it’s a regular 4PM. That is just a name given to the devices.
You can submit a bug on Github so I can further investigate when I have more time. But before you do, please do check if the capabilities are really not added.
Thank you for the quick reply! I’m still new to the home automation and it seems I simply was impatient. After checking in a few hours later all meters were updating as they should :).
I’m currently investigating how, within the ‘energy’ section, to designate the Shelly Pro 4PM channels not as devices IN a zone, but as the ACTUAL zones themselves. But that might be a question for somewhere else.
After update to 3.5.7
The Shelly 2.5 in roller shutter mode didn’t close fully.
I managed to figure out that the percentage „optical middle“ off of 50% is the percentage the roller shutter stops befor closing.
Example.
Roller shutter 1 have optical middle at 0.63.
When I close it, it will stop at 13%.
I have set all shutters back to 0.5 and it worked again.
Did the optical middle have no function after this update?
Edit:
I have to say that I passthru the informations via homeykit to homekit. And steer the devices via home app.
Never used homey app for this.
Never have an issue like this with Shellycloud->Shelly for homey->homeykit->homekit
Regards
Tohmc
A bug was fixed in this functionality which changed the behavior a little. If you can not fully close the blinds there might be a different bug but you are the first to report this behavior. Have you tried to recalibrate blinds?
~24 hours ago all my Shelly devices stopped getting refreshed (1PM, H&T, Motion). I can switch 1PMs on and off form Homey but no feedback of motion, temperature, energy consumption, anything. Checked my devices on Shelly Cloud and they work perfectly fine there. I saw the Shelly app was updated. What do I do wrong?
I’ll look into it.
Release v3.0.7 - 2022-02-07
  • Important change: If you recently paired any devices with Homy Cloud/Beta you will need to re-pair your devices to make sure it receives status updates
  • Added support for Shelly Plus i4 for Homey Cloud
  • Possible fix for rollershutters not updating to the correct position when halfway setting is set.
Due to a bug in one of the latest releases devices paird with Homey Cloud/Beta did not receive any status after pairing. If this release does not fix it automagically you will need to re-pair these devices to solve the issue.
