Could you post your flow?
Just tested this again. Works fine for me on 3.3.8. Do you perhaps have some alternate configuration like set it to a reversed switch? And have you already tried to remove the action card and re-add it to the flow. This sometimes resolves issues as well.
hi phuturist,
i just re-added the shelly1 card and changed from switch state temporary to switch on. this works (the other card not). i am happy again.
cheers
v3.4.0 - 2021-09-14
- Fixed an issue with dimming on Shelly Vintage.
- Possibly fixed an issue with the intelligent action for Shelly 2(.5) roller shutter.
- Added support for Door/Window, Motion, Flood, Humidity/Temperature and Smoke sensors on Homey Cloud.
Hi @Phuturist
Iâve installed the new test version, intelligent action on roller shutter still doesnât work.
Iâve created a simple flow to test it âwhen- this flow is started/ then - intelligent action on a roller shadeâ
If you want me to send you a diagnostic report or anything else for you to check just tell me the steps i should take to send you whatever info you need, also if i should do it with the stable or the test version.
Thanks.
Apologies for slow reply I didnât receive any notifications and have been working. I am now on version 3.4.0 of the app and still not working. I donât have Shelly set to reversed switch. Power On default is set to Off, Button type is set to Detached as it has been. I can still activate the Shelly via Devices Tab but it doesnât work in flows, other devices in those flows are still working.
Have noticed that since most recent firmware update for Shelly my Door Window sensors are shown as offline in Shelly app as well as Homey.
Interesting, do you then have another card for turning Shelly 1 back off again after a delay?
Not thatâs interesting as that does work in a flow. I replaced the Switch On Temporarily Card with Turn On and Turn Off (with a 1 second delay) and the flow works again.
Happy nut curious behaviour
Can you test the version in the test channel. Shelly App voor Homey | Homey
Can you test the flipback action card for the version in the test channel: Shelly App voor Homey | Homey
Yap, intelligent action itâs working again on this test version.
I have a flow which uses the Shelly 1 Switch State Temporary card, but Iâve found that maybe for the last few weeks (even months) itâs not been working.
Itâs related to a temp call so assumed the temp was the fault but changed it and it seems this call isnât workingâŚ
Anyone else using this and seeing issues?
Edit: should probably read the messages above⌠Looks like itâs not just me!
Awesome. 3.4.1 smart actions are working again. Many thanks
v3.4.1 - 2021-09-15
- Initial state of devices added to Homey Cloud is now updated.
- Fixed the intelligent action for rollershutter devices
- Removed some deprecated flow cards, make sure to fix your flows if you missed the previous announcements.
Tried a couple of time with manual update and now works.
Thanks for the app (seems to be) working great, one thing I was missing an option of seeing the connection quality per device, e.g. the WIFI RSSI DB as itâs mentioned in the shelly webapp
would this be possible?
Sure, please submit a feature request on GitHub for this.
v3.4.2 - 2021-09-16
- Add support for Shelly Plus 1 and Shelly Plus 1PM next generation devices.
- Fixed a bug with the flipback switch for relay devices.
Done, I just hope this is the correct github
Thanks!
In shelly 2.5 the card only work in relay 1.
Thanks for your support.
