Then I shell do it for the 3rd time.
Edit
The KNMI device is now indeed KNMI 2.0. With values
Then I wrote here a whole text about problems with “Deze Flow”(This Flow) data.
But when I used the card “Haal nieuwe gegevens”.(“Get new data") then flows with “Deze Flow”(This Flow) data worked perfectly.
But if you want data directly you can put in the Filter “KNMI” and get from there the value.
Then I needed first the explanation what the If cart “Nieuwe gegevens van het KNMI” (“New data from the KNMI”) does.
There was nothing on my timeline.
It’s still code yellow, some where in the country, so there also no result if it’s working.
Are also other trigger cards and besides, you can see that the capabilities update. The app works! 100%
That is a disappointing answer.
So I stop testing and delete all the flows
There is no other reason for me to use this app.
Then just one click on the KNMI side link for the right and better alarm codes.
Version 2.0.4
New Live version!
Download the new version in the Homey App Store!
Changelog
New
- New: 15 image tokens and camera capabilities: KNMI Webcam, Weather Radar, Precipitation + Thunderstorm Radar, Forecast Today, Forecast Tonight, Forecast Tomorrow, Satellite, Max. Temp, Min. Temp, Amount of Precipitation, Snow cover, Max. Wind, Max. Sun, Sun Strength Today, Sun Strength Tomorrow.
NOTE
The images above concern Global Tokens. This means, that you can choose the images without using any if, when or Than cards from the KNMI 2.0 app
More - apps - KNMI 2.0 - settings wheel right top - send diagnostic report (put your email and issues in the input field to make it easier)
Fair’s fair.
My compliments for the Global Tokens.
All the things needed before, like cam’s, I could deleted in Homey.
This way are the code best way to show.
For others users: the tiles can be small because when you click on it they give a bigger picture.
With [Esc] you close that again.
Look later if I like more to put in this Dashboard of @skogsaas
Nice dashboard!!
And it’s finally code green!
Version 2.0.6
New Test version!
Changelog
New
- Condition card for Weather Alerts
Version 2.0.9
New Test version!
Changelog
New
- Weather Alarm message (trigger card, token and device capability)
Version 2.0.11
New Test version!
Changelog
New
- Weather Alert water/sea (Image token and device capability)
- Global token information url Weather Alert water/sea
To use the functionality of weather alert message, you need to uninstall and reinstall the device. After that, run through all your flows.
I’m going to see if I can build in a repair function. But for now, this is the solution for now.
Very nice app. Can you expand the example flows in post 27. I can’t read them because the text is too small. Thank you.
Thx! Can you download it and zoom in?
I did, but I can’t still read it.
Social media KNMI - Homey app
Version 2.1.0
New Test version!
Changelog
New
- App improvement and stable version
And … your Dashboard
All KNMI tiles empty.
Version 2.1.1
New Test version!
Changelog
New
- conditions cards for feel temperature, current temperature, wind speed
When restoring the dashboard, the weather code for today turned out to be green again at 09:21in that image.
In the data of all weather parameters still yellow.
There will also be no adjustment when collecting manually.
