[APP][Pro&Cloud] DoorBird
I had my Doorbirds working with HP23 for several years now. I switched to HP26. The 2 doorbirds are connected, but the cards that something is moving are not triggered.
Any ideas?
After the change of IP address had to re-install the device at Homey after which it worked flawlessly again.
Thx for the input!
Just resetting the notification URLs in the devices’ maintenance section was enough.
Great, I was about to ask you…. Doorbird tech support, where I asked for it, told me I had to ask you :wink:
I encounter a problem with a flow, this one does not start (action “the doorbell rings”)
in manual, the flow starts and launches without worry
Do you have an idea?
Thank you in advance
Does the problem still exist?
The Advanced Flow itself looks fine. The problem is most likely that the DoorBird is not configured to send the doorbell event to Homey.
  1. Open the DoorBird app.
  2. Go to Settings → Administration.
  3. Log in with the DoorBird administrator account.
  4. Open Schedule for doorbell.
  5. Select HTTP calls in the first drop-down menu.
  6. Select Homey Doorbell Trigger in the second drop-down menu.
  7. Fill/activate the complete schedule so that the HTTP call is allowed at all times.
  8. Save the configuration.
  9. Press the physical DoorBird bell button and check whether the Homey Flow now starts.
If Homey Doorbell Trigger does not appear in the DoorBird HTTP-call list, first go to the DoorBird app settings in Homey and run the function that adds/sets the DoorBird HTTP notification URLs. Then return to the DoorBird app and configure the schedule again.
One important detail: make sure Homey Doorbell Trigger is assigned to the doorbell schedule, not to the motion-event schedule. Otherwise Homey may react to motion instead of an actual button press.
I would like to ask briefly if there is any news about this?
