Chronograph v3.0.0 is now available for testing!
Versions 2.3.1 and 3.0.0 bring new ways to monitor and control your timers, stopwatches and transitions directly from your Homey dashboard.
This update is currently in test, not yet a stable release.
Dashboard widgets
- Dedicated Timer, Stopwatch and Transition widgets with controls to start, pause, resume and stop your chronographs.
- Customizable designs, color schemes and icons.
- Reuse saved Flow/API start values when available.
Multiple Chronographs widget
Display up to 10 timers, stopwatches and transitions in a single widget, arranged in up to three columns. Configure each tile individually with its own design, colors, icon and display name.
Widget designer
Create your own widget layouts and color schemes to match your dashboard.
Widget guide · Widget designer guide
Flow improvements
- Added a Flow card for elapsed timer duration.
- Clarified that the timer split Flow card uses remaining duration.
Under the hood
Improved translations, improved app and widget performance, and reduced resource usage.
Important for HomeyScript and API users
Version 3.0.0 changes the API to use chronograph names instead of IDs. Please update scripts and integrations that use the old ID-based API before switching to this version.
Updated documentation
The wiki now includes guides for Flow cards, math expressions, Better Logic Library support, devices, widgets, the widget designer and app integrations.
Dashboard widgets require Homey software 12.3.0 or later and are not supported on Homey Cloud.
Help test the update
Feedback and screenshots of your dashboards are welcome below! Please report bugs on GitHub Issues, including your app version, Homey software version and steps to reproduce the problem.
Thanks for testing! ![]()
