Hèb je hier iets aan?
Here are several issues and potential improvements in the provided code snippet:
getSocket Method Empty Implementation:
ThegetSocket
method does not have any implementation, which could be intentional (e.g., for overriding in subclasses) but if not, it should either have a meaningful implementation or be documented as to why it’s empty. -
Reconnection Logic Could Be Improved:
Thereconnect
method clears a timer and attempts to delete a socket from an unspecifiedthis.sockets
object based on network properties. However, there’s no check to see if the socket actually exists before attempting deletion. Additionally, the reconnection is attempted immediately after deletion without any delay or failure handling, which might not be effective in all network conditions. -
Authentication Check Simplification:
TheisAuthenticated
method returns a boolean based on the existence ofthis.networks
. This is overly simplistic as it does not actually check if the session is still valid. The commented part (// TODO: && Date.now() < this.networks.expires_at
) should be implemented to check for session expiration. -
Login Method Error Handling and Redundancy:
Thelogin
method has an initial checkif (this.isLoggingIn)
, which is good for preventing simultaneous login attempts. However, the logic to handle this situation involves a mere 100ms delay before retrying, which may not be sufficient or necessary. Consider implementing a more robust method for handling simultaneous logins, such as using event-driven techniques or a longer, possibly exponential, backoff strategy. -
Exception Handling in Login:
When the login fails (if (!response.ok)
), the method logs and then throws an error. This is generally fine, but the thrown error should also include the HTTP status code for better debugging and error handling. -
Use of Magic Strings and Numbers:
There are several “magic” strings and numbers (like the URL path and the 100ms timeout), which should ideally be defined as constants at the top of the class or module for easier maintenance and configuration. -
Headers Manipulation:
Thedelete this.headers['X-Casambi-Session'];
operation directly manipulates headers without any check. It would be safer and clearer to manage headers in a more controlled manner, especially considering the role of headers in authentication processes.
By addressing these issues, the code can be made more robust, maintainable, and clear in its intent and handling of network operations and authentication.
Here’s a rewritten version of the provided code, incorporating better practices, including error handling, use of constants for configuration values, and more structured login control to handle concurrency effectively:
class NetworkManager {
private static readonly BASE_URL = 'https://api.example.com';
private static readonly AUTHENTICATE_URL = `${NetworkManager.BASE_URL}/networks/session`;
private static readonly RECONNECT_DELAY_MS = 1000; // 1 second delay for reconnection
private isLoggingIn = false;
private sockets: { [key: string]: WebSocket } = {};
private networks: NetworkList | null = null;
private headers: { [key: string]: string } = {};
constructor(private username: string, private password: string) {}
protected getSocket(network: Network): WebSocket {
const key = `${network.id}-${network.sessionId}`;
let socket = this.sockets[key];
if (!socket) {
socket = new WebSocket(NetworkManager.BASE_URL);
this.sockets[key] = socket;
return socket;
protected reconnect(network: Network) {
const existingTimer = this.sockets[key];
if (existingTimer) {
clearInterval(existingTimer as unknown as NodeJS.Timer);
delete this.sockets[key];
setTimeout(() => this.getSocket(network), NetworkManager.RECONNECT_DELAY_MS);
protected isAuthenticated(): boolean {
return this.networks !== null && Date.now() < (this.networks.expires_at ?? Number.MAX_VALUE);
protected async login(): Promise<NetworkList> {
if (this.isLoggingIn) {
await new Promise(resolve => setTimeout(resolve, NetworkManager.RECONNECT_DELAY_MS));
return this.getNetworks();
this.isLoggingIn = true;
try {
const response = await fetch(NetworkManager.AUTHENTICATE_URL, {
method: 'POST',
body: JSON.stringify({ email: this.username, password: this.password }),
headers: this.headers as HeadersInit,
if (!response.ok) {
const errorText = await response.text();
console.error(`Authentication failed for ${this.username}: ${errorText}`);
throw new Error(`Authentication failed with status ${response.status}: ${errorText}`);
this.networks = await response.json() as NetworkList;
console.log(`Authentication succeeded for ${this.username}`);
return this.networks;
} finally {
this.isLoggingIn = false;
private getNetworks(): NetworkList {
if (!this.networks) {
throw new Error("No network information available.");
Key Changes and Improvements:
- Constant Usage: Constants are used for URLs and time delays to make configuration easier and the code cleaner.
- Error Handling in Login: The login function now includes better handling with try-finally to ensure
this.isLoggingIn
is reset properly. - Reconnect Delay: A constant is used for the reconnection delay, and the reconnection logic checks if the socket exists before attempting to reconnect.
- Session Validation: The
isAuthenticated
method now correctly validates the session based on an expiration time. - Networks Getter: A private method
getNetworks
safely retrieves network information, throwing an error if it’s not available.
This rewrite aims to enhance readability, maintainability, and error handling in the code.
