[APP][Pro] Broadlink App
Not at the moment, I don’t use the app myself anymore.
In thermostats (Floureon, Beok), I cannot change the temperature above +30⁰C, even if I set the maximum value to +90⁰C in the limit value settings. The display always stays between 0-30⁰ and because of this +30⁰ is the maximum value in manual adjustment. With automation, you can set a value above +30⁰, but I would like to adjust the thermostat manually, for example according to spot electricity. Could this be changed so that the maximum value on the screen would change according to the maximum value set in the settings?
Hi @Remko; I was wondering if you are going to update your app to sdk3 in order to get it working on the new Homey
I lost faith in this and bought a Tuya RF recorder to use with the Tuya cloud app. Still not ideal knowing homey could do it itself but at least the Tuya app has more traction/visibility.
Thanks for the suggestion! I didnt know this device yet…
Nice that there is a kind of solution. How do you use it? Are you able to send a kind of scenes from Homey that triggers commands to send from this device or so?
And indeed, its a shame that Homey is not able to do this… It really make no sense. Maybe good that a lot of people do a feature request at Athom. I did this allready a couple of times.
So you record the IR/RF input with the device and create a “tap-to-run” scene that you can then use with the Tuya Cloud app in flows.
I think the easiest way is that someone requests to take over the app.
Maybe @Emile wants to do it to compensate for the RF / IR not working as promised with Homey
Great. Do you have a link to the device?
When you don’t mind ordering from Uncle Ali:
What Peter said.
More specifically I have this one;
€ 13,99 36% Off | Tuya Smart RF IR Remote Control WiFi Smart Home for Air Conditioner ALL TV LG TV Support Alexa,Google Home
https://a.aliexpress.com/_ExOnmKN
Thanks! Can you say something about the range? Is it the same as with a broadlink rm pro 3?
Same or better :slight_smile:
Thanks. I ordered one! :partying_face:
EDIT: Working great!
Hi!
What app do you use in Homey? Can’t find anyone listing this item.
Regards
Peter
Tuya cloud
Thanks @Hannes85, ive had a look in the Tuya Cloud app, and it has button, light, Sensor, thermostat, wall plug and wall covering. which device do i use to add the RF bridge/remote? sorry if this is a silly question. regards, Rick
Also, is there a reason why my Broadlink RM Pro forgets RF signals, and can i fix it
? it is amazingly frustrating
There is no direct supported device, but that is not the end of it.
You can try the ‘tap-to-run’ or ‘raw commands’ workarounds.
No way to fix it. Also; the app doesn’t forget it just doesn’t show them anymore (some kind of bug). The actual command will still work once you added it to a flow.
For Tuya cloud: indeed it’s the tap-to-run function you use to make it work.
Any news on an update of this app to SDK3, @Remko?
I don’t have much hope, though:
