Change the temperature in Homey works - but start or stop the box is not working
OK, I think I found a bug regarding on/off - please install test version of the app from here: BleBox | Homey and please let me know if now it works for you.
HI
Thank you
now it works
Hi
Any chance you could add below module ? much appriciated thank you
Device identifier: ae0bfbec70db
Device type: smartWindowBox
Hardware version: O-sW-0.1
Firmware version: 0.920
API type: smartWindowBox
API level: 20190911
Hello, I think yes - but you’ll have to wait a bit for it, as I’ve got really busy times recently.
thank you so much
I was able to connect it once, but it was not visible from Homey, and so I deleted it and tryed to add again,
but not able to add SaunaBox, getting message “Driver Name is not defined”
Does your saunaBox have a static IP assigned in your DHCP server (router)?
first of all thank you for maintaining the BleBox app for Homey.
I am currently trying to add two BleBox sensors to my Homey, but unfortunately I am running into some issues.
1. humiditySensor_v2 not discovered
The sensor is connected to Wi-Fi and reachable in the network, but Homey cannot discover it automatically and adding it via the correct fixed IP address also fails.
The /info response of the device is:
{“device”:{“deviceName”:“Feuchtigkeit Aussen”,“type”:“multiSensor”,“product”:“humiditySensor_v2”,“hv”:“tS-2.0”,“fv”:“0.1115”,“universe”:0,“apiLevel”:“20220505”,“categories”:[4,7],“id”:“xx”,“ip”:“192.168.xx”,“availableFv”:null}}
2. luxSensor support
I also have a BleBox Lux Sensor which I would like to integrate, but it seems this device type might not yet be supported.
Its /info response looks like this:
{“device”:{“deviceName”:“My luxSensor”,“type”:“multiSensor”,“product”:“luxSensor”,“hv”:“lS_1.0”,“fv”:“0.1002”,“universe”:0,“apiLevel”:“20220505”,“categories”:[4],“id”:“xx”,“ip”:“192.168.xx”,“availableFv”:null}}
Could you please advise if these devices should already work with the app or if support for them could be added?
Thank you very much!
None of those devices are supported at the moment. I hope to have some time in the next weeks to add them.
Someone pointed out to me by chance that your app now supports the proxiBox, which wasn’t the case before.
So I added the proxiBox through your app, which worked without any issues. I didn’t make any changes to the settings during the setup process. However, the Flow cards aren’t working, and I don’t know why.
But when I try to save a changes in the Advanced Device Settings, the following error message appears:
Do you have any idea what the error means?
I’ve also sent you a diagnostic report: 1cf9c216-c528-479f-bee3-b133f2137fa3
Thanks in advance!
I found a little bug. I’ve just published new test version at https://homey.app/pl-pl/app/eu.blebox/BleBox/test/ - please install it and let me know if it’s ok for you.
I added it to the new test version - please let me know if it works for you now.
I installed the test version and tried to add the devices via mDNS as well as via direct IP address. In both cases, no devices were found.
H
Please confirm that you are trying on version 3.99.13, your humiditySensor has a static IP address and it responds on http://IP/info and it doesn’t in Homey (via the same IP).
Sorry, it was accidentally reverted to the production version right before I tested it. The humidity sensors are working perfectly. The light sensor isn’t integrated yet, is it?
I tried the following flow cards…
– Any edge has been detected on input
– Button has been clicked shortly
– Button has been clicked long
…and they work as expected. ![]()
Until now I didn’t checked these flow cards:
– Falling edge has been detected on input
– Rising edge has been detected on input
Just for info.
Thank you very much for your excellent and prompt support! ![]()
No, luxSensor is not yet integrated. Thank you for the test.
Thanks for the tests.
Hello, luxSensor support has just been added to the test version - give me a note if it works for you: https://homey.app/pl-pl/app/eu.blebox/test/
