The Breezy recuperators and iFan fans will arrive beginning of June… I will let you know how they work…
I ordered them from Hungary:
Br
Br
@Kaoh Do you have a chance to take a quick look at it? The integration is sorely missed.
i did gave it a look, sorry for not reporting back.
2026-05-06T04:45:40.269Z [log] [ManagerDrivers] [Driver:vento-expert] Current we located 0 devices, lets see if we found more: amount located 0
2026-05-06T04:45:40.270Z [log] [ManagerDrivers] [Driver:smart-wifi] Current we located 0 devices, lets see if we found more: amount located 0
It doesnt seem to locate the devices. PLease update the app to the newest version (its gone public last week) and try again, also try the different drivers. I am filtering a bit more on device types, they may have moved.
Hi Kaoh,
picking up the earlier question about the new VENTO inHome series — I now have one in use and tested it with the app, so here’s some real-world data for you.
Device: Blauberg VENTO inHome W (decentralized single-room HRV with enthalpy heat exchanger). In the Blauberg Home app it’s added as device type “VENTO V.2”. Its Wi-Fi module is an Espressif (ESP) chip.
Setup: Homey Pro (Early 2023), connected over Wi-Fi. Latest Blauberg Vento app (the version that offers HRV Wi-Fi / Smart Wi-Fi / Vento Expert).
What works: Full local control through the Blauberg Home app works even with “device management via cloud server” switched off (phone on the local network). So local LAN communication with the unit is clearly fine and the unit is reachable locally.
What doesn’t: Homey “Add device” finds nothing for any of the three types (HRV Wi-Fi, Smart Wi-Fi, Vento Expert). I tried restarting the app and waiting several minutes, power-cycling the fan and scanning immediately afterwards, and a full Homey reboot. There’s also no option to add the device by entering its IP manually.
My guess is that the inHome announces/responds to the discovery differently than the Vento Expert, so it never shows up — but I’m happy to test anything you’d like, or pull more reports.
I just send a diagnose report a couple of minuts agao.
(Created right after a failed “Add device → HRV Wi-Fi” attempt.)
Thanks a lot for the app and for taking a look!
See the new testing version in the store, it now support manual adds and a potentially more rebost detection system. Please give it a try with the automatic option first. If still not detected use the manual one. Once added like that if it doesnt work as expected send me a new diag report (added some more logs on device identifiers on the response when adding it manually). This will help me determine what they are repsonding, we worked from pdf’s so far.
Now the device was found automatically!
Thank you so much!
Let me show my appreciation with a tip of 20€!
Let me know if you need any information on my device in the future to further develop the application.
André
I dont take tips, you are welcome to donate it to a charity in your neighbourhood ![]()
Happy that it is resolved finally.
This version also includes network connectivity checking improvements.
Send me a diagnostic report, I’ll check what we are receiving
the diagnostic report was send…
Br,
Benjamin
Can you try this test version?
Blauberg Vento | Homey
The iFan seems to give answer to unsupported registers, I skipp unavailable register if they dont answer, but they decided to answer BUT with an ‘i am not supported’ answer.
I tried to handle those
Hi I tested this version…
On/Off is working, RPM is working…
But no humidity, temperature information, and status for low battery is on (new battery is in the device)…
Please send a new diagnostic report
If I read the modbus specs, I dont see that it exposes humidity/temperature etc as a measurement. So looks like your out of luck there. I do see it exposes IF it is running due to those conditions.
The battery state is indedd weird, it should give 0 if empty or 1 if not empty, so please send me those diagnostics so I can see what it returns.
More fine tuning on your device based on your log.
There are just no temp or humidity sensors exposed by the modbus. But there is a true/false if the fan is on due to a high temp or humidity. So I did implement that one for the device.
I think this covers all that is exposed by the device, let me know how it works.
So do not Expect humidity and temperature readings, they will not be available.
It’s working for me again now! I added the device by entering the IP address manually.
Hello! I have the same Flexit Aura but can’t get it to work with Homey. How did you manage to connect yours to Homey Pro?
