Hi, SlicingHaunt
Yes that is true, I have a new ZenWiFi Pro XT12 with GuestNet Pro. The Phone is there in the list of online devices - Even when phone (Pixal 7) is off.
Hi, SlicingHaunt
Thanks for the update. I am now on 2.2.1 exp and magically my routers and access points now again report the amount of connected devices
Love this app, thanks for all your great work! I do have a question though; when setting up a flow for running a speedtest, in what format (and where do I find) a server to point the card toā¦?
If i click inside the bubble i get a list of available options.
Hello @SlicingHaunt ,
Is it possible for you to add two āWhenā cards?
Nr.1 When: CPU-usage-changed, with tag
Nr.2 When: Memory-usage-changed, with tag
Regards
Marius
Hi Marius,
I have created a new github issue to not forget to add the triggers in the next update.
I wonāt promise it soon due to being busy in my private life, but I will add them.
https://github.com/StefanIndustries/HomeyAsusWRT/issues/27
Iāve an issue with my Asus ZenWifi AX. Iām using the same credentials to enter in the router by the web, but then the app is processing & giving me the message āTimed out after 30000ms.ā
I tried to check the settings inside the router but I couldnāt find the proper configurationā¦Do I miss something? Thank you
Is there nobody that can help? Thanks
