Routers with an App
Which routers do have an app in Homey?
Try a search on the app page: https://apps.athom.com/search?query=Router
https://apps.athom.com/app/com.ubnt.unifi
Netgear, AVM Fritzbox, Unifi
Does the app comply with all Netgear routers?
Did a check for u at apps.athom.com :joy:
" Supported routers
In general: If you can use the Nighthawk or Genie app to manage the router, then this Homey app will most likely work. Some functionality, like blocking/unblocking an attached device, only work on certain router types. MAKE SURE YOU ARE ON THE LATEST ROUTER FIRMWARE!
You can check your router version by browsing to routerlogin.net. According to the Genie and NETGEAR Nighthawk app description, at least the following routers or extenders should work:
Nighthawk: AX8 AX12 Tri-Band AX12 XR300 XR450 XR500 XR700 AC2100 AC2400 AC2600 R9000 R8900 R8500 R8300 R8000 R8000P R7900P R7960P R7900 R7800 R7000P R7000 R6900P R6900v2 R6900 R6850 R6800 R7450 R6700v3 R6700v2 R6400v2 R6400 R6350 R6260 R6230 R6220 R6120 R6080 R6020
Nighthawk Extenders: EX7700
Other Wi-Fi Routers: Orbi AC1450 Centria (WNDR4700, WND4720) JNR1010 JNR3210 JR6150 JWNR2010 R6050 R6100 R6200 R6250 R6300 R7500 WNDR3400v2 WNDR3700v3 WNDR3800 WNDR4000 WNDR4300 WNDR4500 WNDRMAC WNR1000v2 WNR1500 WNR2020 WNR2020v2 WNR2000v3 WNR2200 WNR2500 WNR3500Lv2 WNR612v2 WNR614
DSL Modem Gateways: DGN2200B DGND3700B D3600 D6000 D6100 D6200 D6000 D6200B D6300 D6300B D6400 D7000 D7800 DGN1000 DGN2200v3 DGN2200v4 DGND3700v2 DGND3800B DGND4000
Cable Gateway: C7000 C6300 C6250 C3700 C3000 N450"
Thanks! Sorry for being lazy :pensive:
