Control your home network and keep track of connected devices.
Monitor your realtime internet speed, total transmitted data, connection and router status.
Testing new versions:
ASUS WRT app should support the following routers
All ZenWiFi line up
All 802.11ax line up
All ROG Rapture line up
All TUF Gaming line up
Selected DSL routers
Lyra/Lyra mini/Lyra Trio/Lyra Voice (needs to be at least 3.0.0.4.384 version)
Blue Cave
RT-AC5300
RT-AC3100
RT-AC88U
RT-AC3200
RT-AC2900
RT-AC2600
RT-AC2400
RT-AC2200
RT-AC87U/R
RT-AC86U
RT-AC85U
RT-AC85P
RT-AC65P
RT-AC57U
RT-AC68U/R/P/W/UF
RT-AC65U
RT-AC1900
RT-AC1900P/U
RT-AC1750
RT-AC1750 B1
RT-AC66U/R/W
RT-AC66U B1
RT-AC66U+
RT-AC1300UHP/ G+
RT-AC1200
RT-AC1200G/HP/G+/ E/ GU
RT-AC58U
RT-AC56U/R/S
RT-AC55U
RT-AC55UHP
RT-AC53
RT-AC52U B1
RT-AC51U/ U+
RT-ACRH17
RT-ACRH13
RT-N66U/R/W/C1
RT-N18U
RT-N19
RT-N14UHP
RT-N12E B1/C1
RT-N12HP B1
RT-N12VP B1
RT-N12+ B1
RT-N12D1
4G-AC53U
4G-AC68U
*ASUS WRT App does not support the following models:
DSL-AC88U, DSL-AC88U-B, DSL-AC3100, DSL-AC87VG, DSL-AC68VG, DSL-N55U_A1, DSL-N55U_B1, DSL-N10_B1, DSL_N12U_B1, DSL-N10S_B, DSL-N10S
Changelog
v1.0.7
Added LED actions and increased timeout of actions
v1.0.6
Added better logging, error handling, and a reboot action card
v1.0.5
Attempt to leviate unexpected connection issue errors
v1.0.4
Initial release
Planned
most actions available throught the Asus WRT iOS and Android apps
My WAN is not connected (only as wired backhaul), so a lot of stats are not used. Is there a way of hiding these? Or perhaps make other stats available that are useful when using a router solely as access point? I suppose there are a lot of people that use their Asus that way.
And may I suggest displaying the uptime in hours or days or so? Just seconds gest a number that doesnât tell me a lot, without recalculating os to hours or daysâŚ
Again: thanks for your effort. The above is only meant to make the app (even) better! slight_smile:
Hey guys,
Thanks for your responses and positive feedback, really appreciate it and gives a nice boost of energy to keep working on this
I completely forgot there are also users that use their asus router as an AP, so I will look into that for the next releases if I can hide some of the capabilities, but also reduce the amount of http calls that are transmitted to AP routers, just to safe some memory and precious cpu time from Homey (and your router)
My first priority is (besides squashing bugs ofcourse) adding action cards but there are some things that I need to research first, since the homey app is basically a reverse engineered android app from Asus, I just havenât figured out yet how actions are transmitted like restarting the router or enabling/disabling your guest network.
I hope to add some actions in the following week or so, depends a bit on my spare time.
that could be to a number of reasons, I am using the standard login credentials template from Homey and I donât think I can log errors in there, will look into that for the next release.
I have just published a new version to test v1.0.6
This adds more logging and better error handling, this will probably be live in production soon too.
Could you try pairing the device on 1.0.6 and then sending me the log reports if you run into errors? (you can find this button in the app settings in the homey app, it should be above the ârestart appâ button)
I just upgraded from 1.0.5 exp to 1.0.6 exp and added my router without problems now what ever you have done in 1.0.6 solved it for me. I use a ax11000 model. Gonna try out some of the flows now Thanx for your work on this app!!!
Hi, when I try to create a flow when a user came online, nothing is clickable (I use Android), ie neither tags or texts can be changed.
Iâm using Zenwifi XT8 latest version of firmware everywhere)
What am I doing wrong? Should I set up those tags somewhere so I can use them in flows?
Iâm currently investigating a way to implement HTTPS support too.
I am having some issues when trying to get a token from the Asus routers due to the DNS that is hardcoded and forced by homey, therefor skipping the router.asus.com endpointâŚ
It could be that I am not able to implement this at all due to this problem, this will require that the asus routers need to be set to HTTP and HTTPS or HTTP only.
Was hoping that wouldnât be necessary but Athom wonât allow changing DNS server, not even by code before making HTTP requests.
It has been a long time since I had time to work on the app, but I added a few improvements in the next test version. If you have access point devices it will now hide the capabilities that are unneeded for those devices.
I have memory and cpu usage double, one of both not showing a value.
Is it possible to display the uptime in a different unit? Those a re a lot of seconds to recalculate to mins, hours, days, etcâŚ
Hmmm, I had this once during testing too, it seems Homey doesnât like removing or adding capabilities to devices.
If you restart the app a couple of times it should resolve itself. Each time the app starts and initializes the devices it checks if it needs to migrate some capabilities. If it doesnât resolve with a couple of restarts of the app please let me know and I will see if I can improve it further.
Due to the rename of the capabilities it is now possible to select a status icon too like the amount of online devices, if wan is disconnected or cpu or memory usage.
