Yes, I have received this in a diagnostic report already a couple of times, this is also something that happens at my home.
This happens when the router is actively refusing requests and requires a captcha on the login page. I am probably overloading the routers with request since the interval is much faster than in the previous versions.
Iâm looking into a solution in the app for the next update. In the meantime a solution could be to disable captcha at login in your router settings. (but I wouldnât recommend this)
Version 2.0.7 is ready for testing.
This should have fixed login issues and network issues for networks with only a single router configured.
Please let me know if it has resolved your issues since I am unable to test this solution myself.
I have no problems with v2.0.8 on my HP19, but on my HP23 the problem still exists (same app version, Homey RC69).
After a while Homey looses connection with both my XT8âs, when login captcha is enabledâŚ
Send you a diagnostic report: 70fde1a2-62ba-4633-b9ce-01be7f0c9aba if that might help youâŚ
Do you have a Homey Pro 2023 or earlier, @RickardDehlin?
Hi, I re-added these triggers and conditions, you can find them in the latest test version.
this version also has improved stability when a router is behaving a bit different and doesnât respond well on âwired clientsâ âwireless clientsâ.
I have created a new test version that should help with the ânetwork unavailable for requestsâ problem. This often occurs when the router only responds with error_status 2. Now the Homey app will wait when this happens and retry after 5 minutes before intervalling again once every 1 minute.
Please let me know if the problem still occurs, send me the diagnostic reports (those really help since the last few updates, logging is great!)
I have trouble with the router disabling the guest wifi sporadically⌠Would be awesome with actions to re-enable it somehow. So Iâve been looking into the âweb appâ, and might have identified the relevant POSTs and figured I had to look into HomeyScript-ing it. But adding the feature to this app would probably be better, if itâs can be done. It seems to refer to them by wl_unit and wl_subunit in the requests.
Edit: Have now successfully achieved this using HomeyScript
@SlicingHaunt : Do you have a code repo somewhere where one might contribute, perhaps?
Yes, see the app store page for the source code or the first post of this thread.
Most of the code is now abstracted behind a npm package that I update seperately, you can find that on npmjs under ânode-asuswrtâ with also a link to the source code.
Using HomeyPro 23 and V2.0.8 but had many disconnects that could only be solved by restarting the App (have 1 Blue Cave and 3 CT8). Just switched to 2.0.13 with the result that devices were properly detected but no data was transmitted/updated for more than 20 mins - practically none at all. So switched back to 2.0.8 and everything starts to work again.
Is this a known issue in 2.0.13 and/Or are you interested in diagnostic report(s) for 2.0.8 and/or 2.0.13.
Thx. Keep up the good work - very useful for me to detect if my son plays on the xBox while i am awayâŚ
Hmm, that is odd. there are practically no changes besides error handling between v2.0.8 and v.2.0.13.
Athom just approved the 2.0.13 live.
I have also worked a bit more on it this morning though, you could try out 2.0.14
If this has the same issues for you, please send me the diagnostic report with your name in the description, these are really helpful in finding what is going wrong.
Iâve got the same issue. No data since 12 days. Iâve removed alle devices and related flows, disabled captcha, re-added devices but all fields stays empty. anything I can do about it?
