[APP][Pro] Apple Find My
New app update (:orange_square: TEST: 1.3.0):
:exclamation: TIP:
Read the FAQ → [APP][Pro] Apple Find My - #4 by martijnpoppen
Changelog:
NEW
1. NEW: add disclaimer to pairing about battery life
2. NEW: retry mechanism when API fails
FIXES
1. FIX: set default interval to 1 minute
More - apps - Find My - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
You can install the test version by clicking the link above and press install
Don’t want to be part of this test version? Install the live version → (Find My | Homey)
I installed the app a few hours ago, none of my devices got an update.
I do get emails in my mailbox that something is logging in…
Did I forget something in setting up this flow?
@Quakerix
8c0387ad-db2a-4a7c-a1b7-d9139eaf2126
I just tried the repair device button and it kept loading after I tried logging in…
@Quakerix yep known issue
I did a restart of the app and I got data!
Just no battery-level. So to clarify:
I installed it from the store, added all my devices (including old unused stuff), no updates for a couple of hours, tried a device repair and then an app restart.
@Quakerix ah ok, that issue was fixed in the test version, message before your first post :wink:
The repair problem i’ll fix
Thanks. I will play with the app. Good job!
New app update (:green_square: LIVE: 1.3.1):
:exclamation: TIP:
Changelog:
NEW
FIXES
2. FIX: repair of device keeps loading
@martijnpoppen - great work! thanks!
I was wondering if it would be possible to somehow predefine other zones besides Home in the settings for the individual device, fx “school”, “work” etc.? I may be a noob who doesn’t get the whole picture, but if i would like to achieve to get a notification when my son leaves school, how would i do that? I already has setup a flow which sends a notification when he’s within 300m of x-coordinates. But the leaving-part i cant see how to…? It’s offcourse easy for my to say, not being a developer - at all - but the possibility to give names to several coordinates would make it easier - for me, at least. Anyways, thanks for an otherwise great app :slight_smile:
Quick question: what is the difference between “battery” and “battery level”?
@simtom no difference. These cards get created by homey
@Christian_Bertelsen i’ll check if I can make something like that
Thank you :slightly_smiling_face::slightly_smiling_face:
Hi, i’am missing the last three than cards, i have the latest update of the app, any thoughts?
this is a screenshot of the website then cards not from my app.
@Peter_de_Witte those are app cards. So when you create a flow don’t go to the device but click the app. Then you will find them
Check, thanks Martijn!
@martijnpoppen: Just finished setting up my new Homey and I am very happy with this app!
In my old Homey, I have a lot of flows and apps to check if there was someone at home and now: 1 app and 1 flow ( :partying_face: :partying_face: :partying_face: :partying_face: :partying_face:)
Thanks for the great work! I trully appreciate it and will look for the donate button shortly!
Hi @Frekel
Thanks a lot and also for your kind donation!
Hi @martijnpoppen,
The check for “Is device at home” behave different for these two flows:
Screenshot from 2024-10-04 22-31-18
The returns “False” and follows the yellow link to “Send a whatsapp message” while:
Return “True” or in this case a check mark in the Homey notification.
I am doing something wrong?
Hope to hear from you,
Frank
Note: I also tested this in the advanced flow and this will return that the person is at home:
