[APP][Pro and Cloud] Daikin ONECTA
OK, thanks, i think you need to reautenticate against to Daikin Cloud with user / password.
But for some reason ( don’t no why anymore :frowning: ) i disable the repair functionality in the device settings.
So quik fix is to delete the devices and readd them again but then all flows related to the devices are gone.
Or.
Wait for new version where the repair function is enabled.
l
@Alessandro_Rossi , see test version https://homey.app/a/climate.onecta.daikin/test/ where repair is enable, Just installed it, go to devicesetting and go to repair.
@Ron_Kersten , this test version has also the dutch translation
@horakmar , this test version fixed also the temperature range (will be updated from the cloud )
Hello @Mickel_Luiten, temperature range is now OK. Confirmed. Thank you! :slight_smile:
Thanks, it seems working now, even if it didn’t open any new window for re-authenticating my account, after saying “Click here to open a new window for connecting your account”.
I will try the flows asap and let you know the results, thanks again!!
Hi @Mickel_Luiten,
The ONECTA app is working very good. All ‘old ‘online controller’ flows adjusted. Had just one logic which I couldn’t get working. The ‘and’ statement ‘Power mode’ on/off. Somehow this was not ‘accepted’.
Tried:
  • Powermode = Off ( powermode was off but flow not working. In ‘ test’ a Red Cross appeared as if ‘not true.’
  • Powermode =not On (also Red Cross)
Reason for logic: Powermode must be switched of before regular unctions can be used.
Kind regards,
Eric
@ECort , thanks for reporting , need to check this.
Let you know asap
@ECort fixed in version 3.2.1(test) install thru Daikin ONECTA App voor Homey | Homey
Hi @Mickel_Luiten,
Thanks for the ‘instant’ repomse! Will try new version!
Hi Mickel,
Installed, tested and working! Super!
Strangely one flow based on ‘off’ didn’t run. I’m contributing this to the installation of the new app version during operation of airco. Further tests (with new version) this morning proved all flows performed fine. Will keep an eye on it.
Very happy with update!
One other question: I saw some remarks on humidity. With the Online Controller app it was also possible to set the humidiy levels for the Stylish. Not very important but isn’t supported any more with ONECTA?
Many thanks,
Eric
Great ,. It was a little bug in the flow code.
If the stylish model support humidity i can add that?
Can you confirm that in the daikin ONECTA app humidity is also present?
There are so many models and only 1 API that i can"t see which models has which functionalities.
If humidity is there also the flows will be there
Hi!
I’m looking to install Daikin Ducted (FBA-A) units and have a small question. Can I, with this app, use other thermostats temperature values inside the same room to report back to the airco unit without having the need to use the standard Daikin thermostat? So the airco unit will automatically set it’s fan speed/power/…?
I have Tado in my bedroom which shows the current temperature and I would like to eliminate the use of extra thermostats in the room to control the airco units. Or am I going to have to create extra flows to control the fan speed and not use “automatic” mode of the airco unit itself?
Thx!
@DidierVU , yes can use other (external) thermostats / temperaturesensors.
You do need create flows for that, so if the a thermostat/temperaturesensors. goes below eg 15, turn AC to mode heating with fan speed auto , turn on and heat to 18
same for cooling when a thermostat/temperaturesensors. goes above eg. 22, turn AC to cooling, fan speed to 3 , turn on and cool to 20.
Be creative :slight_smile:
Which functionalities you have on the AC depends on the daikin model.
@Freek_V , check out the TEST version 3.3.0 where the AthermaIII is added.
Can you please run some test if everything works as expected?
Beware that not all flows are implemented yet, if base device(s) works OK i will add the flows in coming weeks.
@Mickel_Luiten , Thanks for taking time to add the Alterhma :grinning:
Unfortunately I get the message: No new devices were found
To be sure my setup is a: Daikin Altherma 5kW Hybrid Heat Pump connected to: LAN adapter BRP069A62
I think the difference is the: Daikin Altherma 3 vs Daikin Altherma {0} that i got.
Thanks, for testing, now you have to wait till i have completed the Altherma3 implementation.
If its done i will come back to you to add the Atherma also.
Version 3.5.1. is LIVE.
Changelog :
  • Added Altherma 3 Heatpumps.
  • Added Altherma Hybride Heatpumps.
  • Code improvement.
Hi Mickel!
Thank you for putting effort in the Onecta APP , I have a Altherma 3 Geo and i have problem to add it into Homey it can’t find it , if a test to connect the Altherma hybrid it find it but only return error codes.
Are the Altherma 3 geo supported?
//TT
That’s a new model in the Altherma range for me :frowning:
No its not (yet) supported if the 2 altherma drivers(Altherma3 and Alterma Hybrid) does not working.
The only way i can add the Altherma3 Geo if you willing to share your Daikin Account with me.
If so send me een PM.
Hi Mickel!
I can share my account with you , do you have a more private email ?
Best Regards
Thomas Torlen
I haven’t been able to see any changes in the temperatures of the connected devices for 4 days (see graphs). The data in the Daikin App changes, but the data is not transferred to Homey. Restart etc. didn’t help. Does anyone have similar problems? Is there a solution?
Thanks
