[APP][Pro and Cloud] Daikin ONECTA
That’s strange, never seen this before.
Let me investigate that.
Did you change the operation mode to fan_only?
As workaround restart the app, should fix the problem .
Thanks for reporting
Can reproduce it, it happens if you quickly change between operation modes.
As the homey mobile app(and web) sends every change it mess up the capability.
Let me think about a possible fix.
@Mickel_Luiten I have HDasboards in which I could change modus and themperature before and now not anymore. I use this regular.
Think this has to do with the subcapabilitys that I using. Look like HDashboards does not support this?!
Capability target_temperature.indoor for temperature and thermostat_mode.operation for the operatiomode.
There is not much I can do about it, just following the guidelines of Athom SDK documentation
Updated to latest version and driver… in phone app i can have it default to target temperature… but in web app that option is not available… is this a bug or is it supoosed to be so
Using Perfecta / Origo ac
Homey dashboard does not regonize Daikin as a thermostat. It did before.
had to do another app restart , but now I see all values are being refreshed and see it also on energy dashboard
See previous message.
Ask Athom to create widget for the Aircondition
I dont fully understand what you meaning with “default to target temp”
Can you explain this.
Default status indicator
Phone:
Web:
That is a bug but at Athom site. let me check if i can report it.
Hi. I´m soon getting a Daikin Synergi (FTXTM30A)
This model is not available in your app… can I chose on of the other and it will work?
Again, If your model can be connected to the cloud and the Daikin ONECTA app (android/iphone) it should also work in homey.
The status indicator in the web-app will be fixed by Athom probely in a next release.
Thank you @Mickel_Luiten for keeping the ONECTA app up to date.
I am interfacing via the Homey cloud api with other apps. All other Homey apps I use (> 40) have as an On or Off capability the value “onoff” except the renewed ONECTA app where it is now “onoff.onoff”. What is the reason?
Edit: your capability names are clear, but differ from other heaters and thermostats (not only onoff).
Belive i have the same model, so yes, it is supported… naming may be different for other countries…
First of all , Airconditioning in not a heater or thermostat. That also the reason to create the new driver under class airconditioning.(this class in added in >=12.0.0)
But there is no special reason i have choose for sub capabilty execpt i am in control of my own flow trigger, actions and conditions instead of the build in one.
Or in short custom capabilties that has the flavour since 12.2.0(Device Capabilities | Homey Apps SDK)
Al my capabilties in the new Air2Air driver are subcapabilties(or custom)
For those interessting :
There a more interfacing apps that only uses the default capabilties but that is not a issue i can solve.
Any plans to implement widgets for this app?
NO
short and clear answer :smiley: want to tell why not?
