[APP][Pro and Cloud] Daikin ONECTA
Thanks for the quick reply, I spoke to Tibber and they have not changed anything. The only thing that got updated is this app that enables Homey to access my Daikin heat pump. (And then Tibber uses that to control it)
Is it possible to downgrade to the old version? I don’t need the new features, I’m only interested in giving Tibber access to my Daikin. :grinning::grinning:
What exactly is your problem and which Daikin unit is connected to homey?
Hi, sorry for the delay.
With version 3.11.1 Tibber was able to control my Daikin, with the new version Tibber see it as a thermostat instead of a heat pump.
So somehow it’s not presented the same way as it was in 3.11.1.
The new version broke the integration and when I try to add it again it will not find it.
Hi again,. Nothing is changed in the app ode only a extra feature. Don’t how to tibber is working…
Maybe you can sol e your problem by adding a virtual device?
@Mickel_Luiten Would it be possible to add the eco mode for Synergi 3?
Nop, eco mode is not supported on any models in the provided API from Daikin.
Sorry
Would it be possible to use the current room temperature as well as a option to switch the heatpump ON or OFF?
I don;t see a reason why not. Just build flow(s)
Even external room tempearture sensors can be used.
Sorry I meant the current room temp from the Daikin console…
Same anwer:-), did you test it already, maybe that the way to know if its works?
Hi @Mickel_Luiten, have an altherma 3 heat pump with a hot water tank. I was wondering if it is possible to also set the temperature of the hot water tank. In Homey I already see an option of setting the temperature of the hot water tank, but that isn’t working. The use case for me is that I want to set the temperature higher when I have an overproduction from my solar panels (or also grid). Already thanks for answering, and hopefully I am not the second one (or more) who is asking ;).
With kind regards, Stefan
For sure there is no tempearature setting on the hotwater tank only reading of the temperature.
And to answer your question: no this is not possible(not provided by the API) only on/off and powerfulmode o/off is there.
Ah too bad, thanks for letting me know! About the temperature setting, this is what i got, therefore the confusion.
Maybe you could try to change the language to make sure there is no translation error…
Hey
I am trying to connect a Daikin altherma heat pump but the connection process keep failing basically after logging I am stuck on the screen “log in on the website of the supplier” I cannot get past this.
I have already tried reinstalling the app clearing my browser history and creating a new daikin account to migrate my products but nothing seems to be working.
I am on a Belgium server not sure if that helps, I can also see after going througj the process that the connection between daikin and homey is established but can’t seem to add the actual product
Using a different browser did the Trick to me. Had to deal with the same problem before.
HI , at the moment there is a issue with 403 forbidden messages du ratelimiting on the homey(cloud) platform. So in the case your not using a HomeyPro this can be the issue.
Trying to solve it asap
Hey that could be the case as I am on the cloud platform while waiting for a homey pro, any way to circumvent this issue ?
Yeay, already adjusted the code but I don’t know what the timeout is on the Daikin platform.
Also in contact with Daikin
