[APP][Pro] Amazon Echo - Looking for testers and contributors
I’m currently testing a complete rewrite of the app which I have migrated to python and it now uses the same underlying library that the official home assistant alexa integration uses. I want to give it until tomorrow to see if there are any crashes before I publish a public test version.
Be aware that there are two breaking changes though. After updating the app you will need go to the settings and fill out your login information (including a currently valid OTP code), so no more logging in via the Amazon proxy. The other breaking change is, if you are using the “Run Routine” action you will need to set those up again.
