[APP][Pro] Amazon Echo - Looking for testers and contributors
You can’t use sms or email otp. only authenticator app based works.
I am noticing delays between triggering the announcement via echo in the flow and the execution of the command, is it only my case or have you noticed same…? (I had issues with zigbee too…)
Hi there
Unfortunately I have connection problems with the echo app.
Since I upgraded to Alexa plus it seems like I have to reconnect to the Amazon server on a daily basis…
Any ideas ?
Thanks a lot
Greets from Germany
Everyone here seems to be struggling with this problem :persevering_face: :frowning:
and again the same problem as a few months ago…
Every day I have to log in again.
in the last problem, I was able to solve it by taking Amazon.com as a server. Unfortunately, it doesn’t work anymore today…
Auch bei mir wird die Verbindung seit etwa 2 bis 3 Tagen täglich unterbrochen. Zuletzt hatte es längere Zeit gut funktioniert. Gibt es hierfür schon eine Lösung?
Außerdem funktioniert die Neuverbindung nur am PC, nicht an meinem Smartphone. Gibt es hierfür eine Erklärung?
