[APP][Pro][Alpha] EmberRF – Direct 433 MHz control for Maxitrol G6R-H4T2 fireplaces
I have been developing EmberRF, an open-source Homey Pro app for direct RF control of Maxitrol G6R-H4T2 fireplaces, using either Homey Pro or a Homey Bridge satellite.
The app supports ignition, off, narrow/broad burner selection, gradual flame adjustment, Homey Flow cards and RF command logging. One interesting discovery was that ignition and broad flame use identical RF data bits but different ending pulses.
The basic commands are working on our test fireplace. We’re now experimenting with longer continuous RF transmissions to make flame adjustment smoother and avoid repeated beeps. The latest alpha includes adjustable Flow duration and a dashboard press-and-hold widget, but these still need physical calibration.
I would welcome feedback from anyone with compatible Maxitrol hardware, experience with Homey’s RF API or ideas for better continuous flame adjustment.
The source code and documentation are available at https://github.com/felixoslo/homey-emberrf
This is an experimental alpha, not a certified gas-safety controller. Physical state feedback is not available.
