[APP][Pro] Faber ITC - Control your Faber Fireplace
Hi everyone!
I’ve been working on a community-developed Faber ITC app for Homey Pro, allowing you to control compatible Faber fireplaces locally through LAN or Bluetooth Low Energy (BLE).
The app has evolved significantly and now includes fireplace controls, sensors, diagnostics, historical statistics and Homey Flow integration.
:white_check_mark: Current features
  • Fireplace control: Turn your fireplace on/off and adjust the flame level.
  • LAN and BLE connectivity: Choose the connection supported by your Faber controller.
  • Duo burner: Control the single/Duo burner configuration on compatible gas fireplaces.
  • Symbiose Light: Separate on/off control where supported.
  • Room temperature and fireplace status: Read operating mode, temperature and available controller information.
  • Remote battery: Battery level monitoring on compatible LAN controllers.
  • Error and warning monitoring: Status sensors, notifications and Homey Flow triggers.
  • Maintenance information: Available service and operating-hour information.
  • Gas consumption: Estimated gas usage for compatible LAN gas fireplaces, including Homey Insights support.
  • Historical statistics: Energy consumption and operating-hour history from supported LAN controllers.
  • BLE diagnostics: Connection status, signal strength at connection time, communication errors and reconnection statistics.
  • Firmware information: Automatic firmware and hardware version retrieval where supported.
  • Electric fireplaces: Model-dependent status sensors, including water-level monitoring and low-water Flow notifications where available.
  • Homey Flows: Automate fireplace status changes, Duo burner configuration, faults, warnings, Bluetooth connectivity and more.
:wrench: How to add your fireplace
LAN connection
Make sure your Faber controller and Homey are connected to the same local network.
After adding the fireplace, open:
Fireplace → Settings → Advanced Settings → Fireplace type
You must select Gas or Electric.
This ensures that gas-specific functions, such as Duo burner control and estimated gas consumption, are only offered when appropriate.
The separate Symbiose Light device does not require this setting.
Bluetooth connection
Before searching for your fireplace, make sure the Faber controller is in Bluetooth pairing mode.
Follow your fireplace’s instructions to activate pairing mode. Keep the controller within Bluetooth range of Homey and disconnect other apps if they are already using the Bluetooth connection.
BLE functionality is still experimental and may differ depending on the controller and firmware version.
:construction: Features not yet supported
There are still some limitations:
  • Symbiose Light dimming: Currently only on/off control is supported.
  • Eco mode: Removed because compatibility could not be reliably confirmed.
  • Advanced electric fireplace controls: Heating, mist generator, fan, RGB lighting and audio controls are not yet fully implemented.
  • Complete BLE consumption statistics: Several consumption and maintenance readings are currently LAN-only.
  • Water-level readings: The sensor is available for electric fireplaces, but it may remain empty if the controller does not provide a supported reading.
  • Automatic fireplace-type detection over LAN: Gas/Electric must currently be selected manually after pairing.
Thanks to everyone helping test and improve the integration! :fire:
Feel free to make a donation to keep the development going → PayPal.Me
Find the latest stable app version here → Faber ITC | Homey
First of all, thank you for building the Faber ITC app. Great work!
I would really love to see a version with Bluetooth support. My fireplace is only controlled via Bluetooth, so unfortunately the current network-only version won’t work for me.
If you decide to develop this, I’d be more than happy to donate as a thank-you for your time and effort. I’m also glad to help test, if that’s useful.
I will launch a test version soon. In this version it should be possible to add the Fireplace but no further functionalities. Probabally going to need some BLE logging once installed from the testers to get functionalities up and running.
BLE test version available Faber ITC | Homey
Keep in mind this is experimental and may not work. If you want to help me and send me logging that would be really helpful.
BLE stable version now live!
Great to see Bluetooth is now live, thanks for the work!
I use Home Assistant and have a Faber MatriX Hybrid with an ITC V3 controller that only has Bluetooth (no LAN/WiFi). I’d like to control it with an ESP32 running ESPHome as a Bluetooth bridge, since I don’t have a Homey.
Would you be willing to share a description of the Bluetooth protocol, or the source code of the BLE part, so I can build the same control in ESPHome? Even a short description of the pairing and command flow would help a lot.
I’m happy to test on my fireplace and share logs and findings back with you and the community. Thanks!
