@Ron_Meijsen you’re setting you driven mileage as your current speed. (3rd tag) Leave tags empty if you don’t have the data. otherwise it gets corrupted in ABRP.
Also the 2nd last tag is wrong. You have plug connected while it should be is charging.
Can somebody explain how I can connect my BMW IX3 to ABRP?
I created a flow to send the SoC to ABRP but nothing happens in ABRP.
In the live connections settings I can only choose between Tronity (payed account), ABRP OBD and generic (API).
There’s no need to select a live data source.
If you add the car first in your ABRP app and then later go to homey add a new ABRP device it will login to ABRP, let you select the car and once you’re sending data via the flowcard it will automatically setup the live data connection
There is a error when try to connect ABRP is the error in the app or ?
Internal Server Error
The server encountered an internal error or misconfiguration and was unable to complete your request.
Please contact the server administrator at contact@iternio.com to inform them of the time this error occurred, and the actions you performed just before this error.
More information about this error may be available in the server error log.
Hi Martijn!
I would appreciate some guidance of how to add an EV to the Homey app. I get stuck after opening manufacturers webpage. I’m logged in, have a premium ABRP subscription and the vehicle is connected via Enode. What should I do to proceed from there?
Thx in advance.
@Kenneth_Ulfberg In theory when you login on the manufuters webpage it should redirect you to the Homey app (or you can go back manually) and then it should find your EV there
Thank you for the quick answer!
Sorry to say but that is in theory I’ve tried several times but without success. When I tried via my phone I got a message stating they couldn’t get my position due to geolocalisation restrictions.
