I think he means this. These routines can be made in Homey flows
Thats right i think they call it scenes in the english hue app
Just another question - really sorry but it is due to total lack of any documentation or manuals -
How can i group different lamps together so for instance 3 spots to switch them on / off together?
If you connected the lights with the hue bridge.
I would prefer to group the lights in the hue app.
Then you can add the light group as an single light through the hue app to homey.
Can you actually do that now? I can’t find a way
thanks for the info. It is really to bad as now i have to start all over programming everything
Thanks for the response. I think I stick with the Group app, however disadvantage of all these options is the inability to set the dim percentage. The lights will therefor be at the dim state they were when last turned on by the hue bridge, in fact it is only half of the solution I am looking for.
How do you get the lights and plugs show from the hue bridge to show up in homey? I’ve added new plugs to the bridge but can’t see them in homey
Fredrik
At the top off this topic the answer is there
If you need documentation and manuals, you’re not ready for home automation, even less for Homey
This forum IS the documentation ![]()
I have the same problem with my Philips Hue impress pedestal. Can’t dim or change color. Have you solved it?
+1 For “zone” and and “virtual-switch” to trigger Hue Labs formulas from Homey
I wasn’t able to include them to homey
→ no device found, so i use them meanwhile with Hue bridge only.
I am pretty sure that the Impress Pedestal hasnt been added, so only has the basic behavior.
I don’t own any of the impress pedestals (just Calla/Lily) but I am going to be added the Hue Impress Outdoor soon. If you send me the device ID ill add the pedestal for you. (it can take a while for change requests to be accepted by Athom).
I am in the same situation as you. I am doing the following:
1- Add a device in Homey
2- Choosing the Philips hue (non Zigbee)
3- I do not see the bridge.
At which stage do you click on the Philips Hue bridge? I really must be missing something here.
Thanks.
Thanks Jamie but it was so unreliable so I bought the Hue bridge and solved it that way. Now its running perfectly.
Awesome news, I also use the hub - it’s great and I love the app. Just be aware that items on the hub do not count towards your homey zigbee mesh
- they are different now
