At the moment no support and updates
Post canāt be empty
Post canāt be empty
Ok.
I thought you meant that other kind of cameraās might work.
But you mean Hikvision cameraās sold by other (OEM) brands.
Post canāt be empty
Hey I have a DS-7600 series. I have tried inputting the ip of a camera but have a similar issue of nothing happening when pressing test or connect. Just wondering where Iām going wrong? Thanks
Mapulu, thanks for your app. I can finally add my cameras in Homey. Now I have tried to add them in a flow, but I canāt get it done. I have tried as soon as there is movement at a certain time that I get a notification or an image on my phone. Have someone might be have a flow or a flow to share this.
I have tried āIfā cart Video movement starting and i have to fill in tags"Camera Number" nothing i canāt fill in to this.
Post canāt be empty
Post canāt be empty
Thanks man.
Iām probs doing something wrong. Still learning. I donāt have a username or password so entered the ip then ticked Sal, then put port as 443?
Post canāt be empty
Post canāt be empty
Thanks for reply and sorry for being a pain. I only just had the system installed by a company so it familiar with the NVR settings. Iāve had a look through settings but canāt the SSL configuration.
I have a somewhat older HikVision DS-7608NI-SE / P NVR with 2 cameraās connected.
I can open the web interface of this NVR, but when I enter the IP adres and login credentials in the HikVision app of my Homey I cannot click the Test Connection or Connect button. It seems these are no real buttons.
I run the Homey app on a Samsung Galaxy S10
Post canāt be empty
I run firmware version V3.0.22 build 170621 on the NVR.
Donāt know if there is ISAPI available? It is connected to HikConnect now for remote access and the cameraās are accesible using the host mode.
The test connection button and connect button donāt seem to do anything at all.
Regards,
Jeroen
Link deleted by moderator.
Iām looking at Hikvision to protect my home.
Iām thinking about buying the Acusense series from hikvision:
- NVR: Hikvision DS-7608NXI-I2/4S 8 channel AcuSense NVR
- outdoor camās: DS-2CD2346G1-I Turret IP AcuSense camera 4MP, 2.8mm (104°) fixed lens, IR LED 50m
before buying, any comments on this? will this work with Homey?
What about the acusense? or is this 100% in the NVR which connects to homey?
any thoughts are welcome!
Thanks
