Not sure what you mean, are referring to the Homey moods?
Yes
So you are using the moods setup in Homey, add several lights including govee lights. Then you select the mood in the Homey app or by flow?
I tried to replicate but my lights respond well to the mood. I also don’t understand what you mean with the delay.
Anyway I can only support the device controls for Homey. The moods use those controls so if the controls work (select color and it reacts) the rest is in Homeys hands.
Also if this format work for your matter devices there is something else wrong, there is no govee app between matter device support
How many lights do you try to control with one mood?
Hi i have 3 govee ledstrips.
in the mood are also 3 hue lights. i use local API
Having an issue that I can’t seem to figure out with a simple flow- “when” it’s sunset - “then” turn outer light to “x” color. The issue I’m having is the light will turn on but it won’t set it to the color I select and will only turn it on to the light color I had previously even though it’s set to a desired color. Any ideas on why this is?
Hi.
Will there be support for the Smart Tower Fan 2 Max ?
Regards.
If someone can give me that api response so I can eee how they are listed in their api I will. But they are not documented right now as device class.
@Kaoh - so I’m trying to add my Govee lights on the Homey Pro mini. I was able to add the local controlled devices with no issue.
However, when I try to add the other lights via the API Key, I get the screen that says “New Devices Found”, but the content just says “Unexpected end of JSON input”. I sent a diagnostic report (11a618ab-f81a-4415-b275-fa4fcb9d6ea7)
I see your reports, I’ll check them out when I have time. Time is very short in supply in my life, so I can’t comment on any timelines. End of next week I have a long weekend, looking to get bored enough to pick up this code again.
No worries! And yeah, sorry for the multiple reports. New to Homey and wasn’t sure I did them right or where they went. So I submitted one with the code before I posted.
No problem, getting more reports is often useful and don’t really spam me.
I got the gaming pixel lamp yesterday. Is it possible to show the energy monitor live in combination with layers?
Go to the device settings in the Homey Govee app for the device you are reffering to.
There is a JSON structured Capabilities list there in the advanced settings, using the Browser version of Homey app you can copy past this JSON and send it to me, ill check if they added this data to the API, I havent seens those yet.
Your getting a n/a response. The Govee API normally only does that if your API key is invalid.
You can try to use a API test tool like Postman to validate this for yourself.
So I requested a new API key, and now it’s working.
Weird, the previous one worked on my Home Assistant setup.
Thanks for looking into this!
Got my Homey Pro setup everything connected. Installed the app and entered my API key. I was able to add my T2. The issue I’m having in HomeKit will turn on and off with my TV commands. However, it either goes full red or white before it turns off and thus defaults to that when it turns on. I then have to then go into the Govee app to reset it to respond to the screen colors. Not sure what I did wrong or if the T2 isn’t fully supported. Thanks in advance for your assistance.
That is weird indeed, there are no color commands send before sending an off command.
I dont have one of those, so it is hard to test and validate.
Did @WrathofKhan send you the response? I’ve been trying and failing to get a response on Postman (it’s my first time using it), but I’m willing to learn in order for the Govee Smart Fan 2 to be available on Homey.
Just pushed a new version online (still in test right now) that supports Fans I hope.
I have a device request. Is it possible to add the GoveeLife Electric Smart Kettle H7173?
