[APP] Google Sheets - Append to Google Sheets from a Flow
Google Sheets
This discussion is started to centralize all Questions, Answers and Information around the app.
Note:
This topic is not actively monitored by Athom. If you have issues with this app, please report it to support@athom.com, mentioning the version of the app + a good description of the issue.
  • Google Sheets User
Report Bugs for this App to the Developers
  • Please use the Link in the App Store and follow the community guidelines, the more information provided the faster it can be solved.
Forum Discussion
Initial Discussion created by @oh2th with info from the community. Ask any Moderator to add/update/correct this Discussion.
Google Sheets - Frequently Asked Questions
(reserved)
I saw the new app Google Sheets and I thought to export my energy use from my p1 dongel of home wizard.
I created a “device” and tried to make a flow.
In the then I can choose a flow card but then I have to choose an item but there are no results for items. Obviously I am on the wrong track. Can some share a flow so I can see how to do this?
Did you create a Google sheet to which it can append data?
Yes I did:
Did you also tick these two boxes when creating the Google Sheets User device?
I overlooked this totally :flushed:
Thank you very much for your quick support.
This open ups a lot of possibilities. :+1:
Can’t Athom make this app open source? It is obviously early in the development but I think it can spin off to numerous good apps. Logging for example.
Great App! Thanks!
In a Homey flow I calculate a value and round this to 2 digits. This value than is uploaded to a Google Sheet with the time stamp. Works great.
The value is added as text, not a number. How can I set the uploaded value to a number?
Thanks
Isn’t that something you configure in the sheet?
Unfortunately, it is not possible to calculate with the value despite changing it to a numerical value. A formula, e.g. calculation of an average value, ends with an error message.
It would be great if there was an option to send the value as a number or as text.
The problem is that a number is sent with a point as a separator. As soon as a comma is entered manually, the calculations also work.
I’ve set the Country setting for the sheet to “United States”, so it accepts a period as decimal separator:
Clever Robert!
I will try that too!
I tried to find this but where to adjust
These settings don’t let me calculate.
“Bestand > Instellingen > Landinstelling”
Probably on a PC in Excel? I am working almost always on my iPad, so I have to search for my laptop then :wink:
Found it. Thanks for your help again. (It was not in the app sheets but web based)
Works for me @robertklep!
Great tip!
Trying to write values to a sheet, and it works fine. Found that I can append several values to several columns in one row by using a “;” to separate the columns. I do have however a value that contains exactly this character, and it is being split up into two columns - and that is not optimal :wink:
Anyone know how to “mark it as one string”? I have tried with " and [ and { with no luck. No matter what I do, if the field contains a ; it will be split up.
